Once you've burnt the latest stretch image to an SD card (I use Etcher on Manjaro) you need to use the trick of copying an empty ssh file and wpa_supplicant.conf to the boot partition
This is the contents of my wpa_supplicant.conf
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
ssid="BTHub-blahblah"
psk="keyblahblah"
Good luck![]()
I created the "wpa_supplicant.conf" in boot partition but I don't think it's working. My router's admin screen cannot locate an IP of my Pi Zero W. I could not locate the "wpa_supplicant.conf" in boot partition after booting when I checked SD card using Win 10 computer. It must been deleted or moved to other directory.
It automatically gets moved into its home location on root partition
/etc/wpa_supplicant/wpa_supplicant.conf
raspbian - Prepare SD card for Wifi on Headless Pi - Raspberry Pi Stack Exchange
-Tim
Thank you, Tim, I repeated the installation and now Shairport is working 🙂 I just repeat UPNP installation - hope this also helps -Josef
If you don't get the result below from the "which" cmd then maybe a missed step in the compile and install for shairport-sync.
pi@rp3:~ $ which shairport-sync
/usr/local/bin/shairport-sync
Just rerun the steps for component 4, and then afterwords the "which" command to confirm the binary exists. Then shairport-sync -V to verify the version.
pi@rp3:~ $ shairport-sync -V
3.1.3-OpenSSL-Avahi-ALSA-stdout-soxr-metadata-sysconfdir:/usr/local/etc
// COMPONENT 4 - Shairport-sync
-Tim
Yes - after repeating the install steps for UPNP - this is also working now 🙂 Maybe i should first have had breakfast before the build this morning... -Josef
So if i accidently copied them from a previous 'legacy' install into the same location in the Beta then they would not work?lol, definitely, you are now an official "Linux Enthusiast".
The adv kernels are a separate Source base. Well have to see whether they pop up again.
-Tim
There is a small in-place update for Beta 6 that upgrades it to Beta 7, probably the last Beta before production 4.0, which will also be an in-place update 🙂
This update fixes some permission issues, removes a bad fat-fingered directory, and has some minor code fixes and updates. It MUST be run from cmd line AND on an un-squashed /var/www !! It might complain about a missing templatesw# directory. This can be ignored. The browser title will revert to "moOde Player" after the update. Use System config to change it.
Also, just to be safe u might want to backup /var/www and /var/local/www directories before applying the update.
sudo /var/www/command/updater.sh r40b6
If u want to examine the update package and its installation script before installing it then run the cmds below.
wget http://moodeaudio.org/downloads/update-r40b6.zip
unzip update-r40b6.zip
cat ./update/install.sh
-Tim
Just a friendly bump 🙂
-Tim
ES9028Q2M-chinese-board..Settings...
Hi Tim,
got here now working Beta7..wonderful (work, especially for this error-free build-recipe 🙂) as said !!
okay, got here at the moment an ES9028Q2M-chinese-board.."Generic-I2S-Hifiberry-DAC" works NOT (i use "Generic-I2S-rpi-dac" instead)..
so far so good..problem is this rpi-dac overlay is limited to 192khz..
had similar problems on other audio-distros before; was solved by using the "ES9023" without anything else, as setting/dtoverlay..
u had also on the supported Dac-list (Audio-Devices)->26. Generic-4 I2S (es9023-audio) and 27. Generic-5 I2S (simple-es9023-audio)...
i think in this (my) case this 26. (9023-audio) would be the right choice, but it didn´t show up/is not available via "Audio-config->Devices->I2S-audio-device.."
only Generic-I2S 1 and 2 (hifiberry+rpi)..
is this more or less a bug or was it determined before that these options are not available for this special dac-chip (sorry for my bad english, i´m (unfortunately ;-) )german) ?
but many many thx again for this wonderful "Moodeaudio" !!!
Hi Tim,
-Tim
I was able to connect to my network using the latest "RASPBIAN STRETCH LITE". However, I could not make it work on MoodeAudio V.3.8.2.
The followings are the contents ong "wpa_supplicant.conf" in boot partition.
country=GB
update_config=1
network={
ssid="KSK-1215-2.4G"
psk="password"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
group=CCMP
auth_alg=OPEN
Hi @kwatch,
Just use a basic set of params
network={
ssid="YourSSID"
scan_ssid=1
psk="YourPASSWORD"
-Tim
network={
ssid="YourSSID"
scan_ssid=1
psk="YourPASSWORD"
-Tim
Hi @kwatch,
network={
ssid="YourSSID"
scan_ssid=1
psk="YourPASSWORD"
-Tim
I tried but did not work.
This time BT works
I built beta 7 today. This time the Bluetooth works. But I am so afraid of if I power off the device the function would be gone.🙁 I will make a copy of this image immediately.
I have 2 more questions:
In build recipe 1.1 line 170, when I try to disable the blue alsa service, I got "Failed to disable unit: No such file or directory." Is this normal ?
In line 622, why it says "see STEP 7 main procedure," what shall I exactly do in this step?
Step # 2
I am just starting and have zippo linux experience. I have the usb with raspian stretch lite inserted into a raspberry pi. Before I screw up would you be able to tell if the linux commands from Tim's instructions are to executed from a specific location? Right know I am here "pi@raspberrypi:~ $
Thanks Tim,
I have now got a result from the command "sudo fdisk -l -o Device,Start,Type | grep 0p" with offsets for the 2 partitions.
I will now work my way through the steps - thanks again.
Rob
Hi @onionhead,
Execute from home directory (~) which is the default location when you logon.
pi@raspberrypi:~ $
-Tim
pi@raspberrypi:~ $
-Tim
Thanks for being so precise in your report 🙂 I'll have a look.
-Tim
Step #1 and Step#2
Thanks for this great (beta) release. The recipe is running without errors.
I thought about a easy way for step1 and step2 for all the "Linux Enthusiasts". Why not start directly with linux?
-tonno
Code:
#STEP 1
cd~
mkdir moodebuild
cd moodebuild
wget [URL]http://downloads.raspberrypi.org/raspbian_lite/images/raspbian_lite-2017-09-08/2017-09-07-raspbian-stretch-lite.zip[/URL]
unzip 2017-09-07-raspbian-stretch-lite.zip
#STEP 2
sudo rm -rf /mnt/tmp*
sudo mkdir /mnt/tmp
sudo mount -v -o offset=4194304 -t vfat ~/moodebuild/2017-09-07-raspbian-stretch-lite.img /mnt/tmp
sudo touch /mnt/tmp/ssh
sudo sed -i "s/init=.*//" /mnt/tmp/cmdline.txt
sudo sed -i "s/quiet.*//" /mnt/tmp/cmdline.txt
sudo sed -i "s/^/net.ifnames=0 /" /mnt/tmp/cmdline.txt
sudo umount /mnt/tmp
sudo mount -v -o offset=48234496 -t ext4 ~/moodebuild/2017-09-07-raspbian-stretch-lite.img /mnt/tmp
sudo rm /mnt/tmp/etc/init.d/resize2fs_once
-Tim
Typo on my part should be STEP 9 instead of 7 but that section needs tuning up anyway. Basically it was a note to myself that the services would have been already disabled in an earlier step thus the # to comment out the cmds.
The other issue, re: bluealsa.service, you should similar to below. If not then post back and I'll help troubleshoot.
pi@rp3:~ $ ls /etc/systemd/system/bluealsa.service
pi@rp3:~ $ sudo systemctl status bluealsa
● bluealsa.service - BluezAlsa proxy
Loaded: loaded (/etc/systemd/system/bluealsa.service; disabled; vendor preset: enabled)
Active: active (running) since Fri 2017-11-03 21:58:05 EDT; 21h ago
Main PID: 972 (bluealsa)
CGroup: /system.slice/bluealsa.service
└─972 /usr/bin/bluealsa
Nov 03 21:58:05 rp3 systemd[1]: Started BluezAlsa proxy.
-Tim
-Tim
Hi Tim,
Sorry, what is the command to upgrade to beta 7? Thx.
Can't login in Step 3
Great Step 2 done. Made image and was able to power up. Boot up pauses at login Enter ssh pi@raspberrypi and enter pwd= raspberry. message login incorrect over and over. One weird thing to note. My keyboard treats shift 2 as as shift " and vice versa. T o make the @ symbol I have to use shift ". Could that be the issue or should I start over with step 2?
Hi @onionhead,
pi@raspberrypi:~ $
-Tim
Hi Gents,
Recently, a few days ago, I've been getting some (not many) pauses and bumps while listening to music. 1 TB hard drive connected to the Pi3, with an external 5A power supply, so, no issues there (I think). All Flac, 44.1, 16 bit, nothing out of the ordinary.
I increased the buffer to 16K and fill up to 30%, and still, occasionally, the music skips.
Any clue where to look at the logs and see what's going on?
Cheers in advance,
Albert
Cheers in advance,
Albert
- PC Based
- Moode Audio Player for Raspberry Pi
