A while back I bought a cheap Chinese TDA 7294 mono amp board off Aliexpress to make a powered speaker simply because it would run off the existing toroidal transformer I had at the time. I am pleased to say it still works great.
Now I've got another toroidal from another dead amp which says it's a PM42E-240v. I'd like to make another powered speaker if I could, somewhere in the region of 100w mono. I can't find any information about this transformer but it's basically got two different outputs, one that's yellow wires 26-0-26 at 1.92a and another section that's blue wires 19-0-19 at .48a that I'd probably just ignore.
Now, to me this 26v sounds a bit suspect at only 1.92a but maybe I can use it for something. Just wondering what sort of similar amp boards out there (cheap) might be the sort of thing to use with this transformer.
+-26 v is LM1875 IC territory. 30 W max unfortunately.
Goes with the 1.92 A, 2^2=4*8ohms=32 watts.
The +-19 is useful for making +-15 for op amp input circuits.
No money, no glory.
No money, no glory.
Sorry but both are wrong.
Rail voltage is 1.4142 x secondary voltge so we are talking +/- 36V rails, absolutely impossible to use LM1875 with such high voltage.
I suggest the OP to get another TDA7294 board which will be very happy with such rails and provide some 60W RMS into 8 ohms.
Nice and useful project.
