Mogul vs. Double-Ended
Quick question. I have a mogul base 250w MH attached to a big heavy M58 ballast. The bulb takes about 10 mins. to warm up to full brightness. Is this because of the ballast or the bulb?
If I hooked it (the bulb) up to an electronic ballast (i.e. Ice Cap) would it still have to warm up or would it be instantly at full brightness? Thanks.
-Willie
I have not tried an electronic ballast, but from what I have read everywhere, yes it will reach full brightnes faster. One thing to consider is if you are using a probe-start bulb, It needs to hit a specific temp before it will reach full brightness. If you are using a pulse start bulb, it will reach full brightness much faster. The way to tell which type the bulb is: probe start has a 3rd electrode in the bulb that is attached to a heat sensative switch in the outer bulb area. A pulse start bulb has only the 2 electrodes at either end of the bulb.
I plan to upgrade to a pulse start soon.
