After a long search I could not find a 15" or 18" woofer with parameters am I looking for:
High Qms (over 20)
High BL
High Vas
Low Mms
Low Fs (under 30hz)
Low inductance
This is going to be a multiple driver 8-12 vented or T/L subwoofer for impactful, dynamic bass at very low listening levels.
Qms doesn't matter at all. Frequency and time response depend on Qts.
Relax that restriction and you have lots of options. Look to short coil pro drivers.
Ron E,
very interesting thank you for replying. Let me clarify please. I will be crossing over the subs at about 100Hz. And I have read that high Qms (or low mech damping) is very important for getting a "lively" sound from a speaker. Was this a referral to the "midrange" range and therefore it is not as important for bass?
I am trying to figure this out: Is it not true that the more mechanically damped a transducer is, the more "dead" it sounds because the mechanical damping is like puttting an absorber on the cone?
It will measure well but not make any music. Your thoughts?
Thanks,
Herman
Thanks,
Herman
>>sounds like what you want is 60hz kickbass
not at all. As far as output, I am looking for a pretty flat response below 100Hz, maybe down to 30Hz.
the 18" RCF we looked at before will go striaght to 30hz in ported box 😉
with two woofer in paralel per side you will have 4ohm load, and max amp/speaker efficiency
Ron E,
Thanks,
Herman
You can have mine.
A high Qms driver will (when it's not connected to anything) ring. A low Qms driver won't.
Introduce an amplifier with a low output impedance (almost anything solid state), and the damping from the effective short circuit across the voice coil will mean it won't ring much at all. Notice how Qes is always very close to Qts: the electrical damping is (I've not seen a modern driver that's contradicted this) the dominant one.
What's your source regarding Qms - it seems like you're taking it to heart, so it must've been somewhere reputable...
A lively bass sound will probably come from one or more peaks in the frequency response, probably in the 60-100Hz range, giving visceral, chest thumping bass. See this thread for more.
Chris
Low Qms implies heavy mechanical losses. It is questionable you would want this in a transducer, because mechanical losses introduce non-linearities.
vac
vac
Qms=2*pi*Fs*Mt/Rms
Qms as a parameter is strictly defined only at the fundamental resonance, where in most drivers electrical damping dominates. The parameter Rms actually changes with frequency, so any attempt to use Qms to assign a "sound" to a driver is pure folly.
A myth. I know of a designer who talks about this - his preference for stiff cones and low loss surrounds is not a "bad" one, but it doesn't really translate to Qms as a T/S parameter. Certainly one can go too far with damping in curvilinear thin poly cones with thick, lossy surrounds and end up with "tupperware" midrange, but the opposite paradigm in terms of a straight metal cone with a low loss surround is just as bad. Most "real" designs are a compromise. The surround termination changes the breakup region...not the bass.
Here is one 15" that matches almost all criteria. More or less.😎
Beyma SM 115/N
http://profesional.beyma.com/pdf/SM-115%20NE.pdf
QMS is not that high, but in relation with low fs and moving mass...this is still one of the most "detailed" bass drivers.
Also check his brother SM 115/K.
Jernej
Beyma SM 115/N
Jernej
chris,
>>What's your source regarding Qms,
The Audio Physics Speakers designer stated that in an interview. You can probably find that online. To me, it seems reasonable that the less damping of the cone, the more of signal is reproduced, I am talking about my personal theory here.
Jernejc, thanks for the Beyma recommendation, they are very interesting.
I have an idea. I will make an experiment by using two 12" woofers that have very similar response modeling in a box. WinISD, they model almost identically as far as bass rolloff, but Qms of one is double of the other. I will burn them in and A/B test them in an identical box and report my findings.
I am talking about these drivers:
Pioneer A30IR50-51F 12" Butyl Surround Woofer
Dayton Audio ST305-8 12" Series II Woofer
Herman
Herman
Hi Noviygera,
Would be interesting to see if you can model this effect.
May I suggest the following for the low Qms driver:
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=296-458
Has Qms of bit over two, half that of the Pioneer, and Xmax comparable to the ST305,
vac
vac
vac
vac
Here's a little experiment.
Turn off your amplifiers.Tap on the woofer cone.
Turn on your amplifiers. Tap on the woofer cone.
What are your observations?
the cone 'rings' less with power amp ON ?
heck, I tried it just now
HUGE difference
with power amp ON, its almost like the box is filled with water
with power amp OFF, more like drumskin
HUGE difference
fine looking woofer, that 12" AurumCantus
Yes, I like the looks to, but would hesitate to work with a driver with such a low Qms.
vac
Tony Gee from Humble Homemade Hifi is advocating for the use of High Qms woofers. He has many projects in his arsenal although I have not heard any of them.
For your reference: http://www.diyaudio.com/forums/mult...me-user-tell-best-bass-i-have-ever-heard.html
I remember John (or Nick?) has mentioned that there're both aluminum or non-metal materials for thier VC formers. Among them, the materials might be the only difference of the drivers' construction. The one with aluminum VC former has a feature as Eddie current shorting ring, thus providing brake force. And this reflects in the Qms (because of the passive nature). According to John (or Nick?), there's no difference in performance (sound quality) between the 2 materials. (The difference is the heat conduction... )
So that leads to a conclusion that Qms is irrelevant to sound quality.
I'd say it's pretty much in sync with what I've heard in many other cases. I can't find any certain relations between the bass sounds I like and the Qms of the woofers.
Again, for the bass sound quality, there're so many other factors to be considered, so many other problems to be solved. So, drop the Qms, step back, see a larger picture.
The best "box bass" i have heard for low level listening is the Onken and even better Onken W with Altec 416 drivers. If you want to go all the way, I would say LARGE horn or IB with low mass and large cones. I run a large horn integrated into a room corner in my basement and an IB with 4x15" in my living room and I would say both meets your (and mine) requirements. For the IB i would go for low mass and a Qt of around 0.5, not higher. I would also not stare at Fs to much, an IB can have alot of output below that and it is easy enough to electrically compensate for that.
BR,
Anders
BR,
Anders
This is not the first time I saw such high praise on Onken W. 😀
How do you compare that to your IB and horn ?
Well...at low levels i must say that i would be happy with any of them. The Altec 416 in a good enclosure is very tuneful and really dynamic sounding. For higher levels i would pick the horn or the IB as i have it. In my set up i do have good response to around 16Hz, both in the horn and the IB and that can not be matched by the Onkens.
BR,
Anders
HUGE difference
Amp off, Qms.
Amp on, Qts.
Since we listen to music with the power amp on, Qts is what matters.
Rms changes with frequency, it could be high at low frequencies and low at high frequencies. Again, despite the changes with frequency in Rms, the published parameter Qms is defined at just one point - driver resonance out of a box. Even putting a driver in a box changes Qms in ways that cannot be predicted by simple T/S theory.
Qms changes the electrical impedance at resonance, not the frequency or time response, unless you have a high output impedance amp - where you would get peaks at resonances - "added warmth", or even "punch".
Qms as a predictor of bass quality is junk science.
Any studies that show this?Low Qms implies heavy mechanical losses. It is questionable you would want this in a transducer, because mechanical losses introduce non-linearities.
vac
Rather, wouldn't the non-linearities inherent to mechanical damping show up in distortion testing?
- Modyfying the parameters of a 15" woofer
