• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Modulus-86: Composite amplifier achieving <0.0004 % THD+N.
Having looked at the structures of connectors on the market, I do not think any is ideal for audio, but each have different design considerations.
Sent from my iPhone using Tapatalk
Songsc if structure is your criteria then you need to look at the worlds highest quality 3 pole audiophile connector "Asgardian Connector". Its made from Californium 252 and is metallurgically bonded with Taffeite.
An acquaintance in the UK would like to have two modulus-86 boards purchased, stuffed, assembled, and soldered by someone knowledgeable and experienced. Anyone interested in helping, please either reply here (s/he is a DIYA member and reads this thread) or by Private Message to me, whichever is most comfortable for you, and I will put you in touch with the final end-user. S/he is a music lover not a parts sourcing expert and soldering wizard. I personally don't know whether the Modulus-86 or the Parallel-86, is wanted. You and s/he can hammer that out when you communicate. I feel confident s/he is willing to compensate you fairly for your time, effort, and expertise.
I will volunteer to do a PCB assembly.
I can Email if you turn on your Email.
Hi Andrew,
Mark was referring to myself, but your PM inbox is full, so I couldn't message you directly.
I need 4 boards for a linkwitz lx-mini. If you'd like to build 2 of them that would be great. I made the offer below to Vacup (see his message above) which I extend to your good self also:
"If I sent you sufficient funds to cover three boards + parts, would your keeping the third be sufficient to compensate you for your time? "
Regards,
Tom
well first you have to work out what is wrong with existing connectors. I used to have a thing for gas tight fischer connectors but just for bling. Hypertac is good if you have military budgets to play with. But for the rest of us there is a neutrik connector that is more than good enough.
Afrad I'm being thick and can't see your email... on your profile page nor anywhere else... my email is my username at gmail dot com.
Hi Thomas, see the attached pic. You just need to click on Andrews Name on any post and you should see the option to send him a PM or email.
Tony.
I'm also willing to deliver assembled and tested modules, though it sounds like there's an offer of assembly in exchange for a bottle (of wine presumably) on the table already. I can't compete with that... Not on price anyway... 🙂
Tom
(Parts cost + shipping cost + bottle) presumably. Since customer is UK based perhaps you could negotiate for a bottle of Ardberg or Dalwhinnie or Bruichladdich. Or maybe a favorite high end grape juice from the Margeaux region of France, that's available in UK but not US.
We the people of California are permitted to praise high end grape juice (which around here is considered a locally-produced agricultural product) and nano-brewed barley malt, but only a polite golf-clap towards grain distillates.
Shipping cost of two assembled PCBs about the same size as modulus-86's, from US to UK, was $19.90. These boards were maybe a little bit heavier (shipped weight 1 lb + 3 oz on the Post Office scale) due to the giant electrolytic capacitors and eight heatsinks. So consider $19.90 a loose upper bound. THIS shipping carton was a perfect fit for two assembled PCBs about modulus-86 size.
The LX-minis should be great. I so nearly built a pair, and may still do when I've given up with my apogees in a small room.
I'm building a pair of LXminis myself, actually. I'll use a (soon to be) spare laptop running Reaper ReaEQ along with my Focusrite Saffire PRO24 sound card for the XO rather than the MiniDSP, though, to avoid the 44.1 -> 48 kHz up-sampling of the MiniDSP.
I'll make sure to post my listening impressions to the extent I'm able once I get them finished.
Try a bottle of Chateau Saint-Estephe (Bordeaux/Medoc) if you ever get the chance. I still remember the bottle I shared with a friend back in the 1990ies. Holy crap that was good stuff...
These days, I'm more a fan of the micro brews, though. We have quite a few stellar breweries in the Pacific Northwest.
Tom
I'd love to hear what you think can be improved compared to Neutrik metal-chassis XLRs and Speakons (and a lot of audiophiles are perfectly happy even with RCA connectors and banana plugs... 🙂 )
When one audiophile recommended the best RCA connector he has experienced, I looked at it, and saw basically the center pin and the ground shell were of the simplest geometry, then the plating was tested to be copper as did the core material. These two things stood out from the usual designs. Normally I would look for these as the minimum. Then I would further consider thinner pins as a more desirable implementation. At the signal level currents are really low, so I would look for solid core with no dissimilar material plating to be of importance throughout the signal paths, including pins. The core radius should be no more than the skin depth of the highest frequency intended.
Speakons were designed for fast connection, idiot proof, and weatherproof as far as I understand, I really have not looked into them in detail.
If you are going single ended you are not after ultimate fidelity. As skin depth at audio frequencies is an urban legend that is also not a worry.
As for dissimilar metals, I've seen problems with nickel plating at 2GHz causing IMD but that was 20 years ago.
Pick an xlr family you like the look of and be happy.
