I have an old Mission DAD5 that uses Philips Bitstream conversion. Now I'd like to put my own DA board into it.
How do I modify this player to get to the internal digital signals? Preferably, I'd get in before the S/PDIF generation.
Hope this player has a decent crystal oscillator and power supplies that I can hack into.
Any schematics out there?
Greetings,
Børge
Greetings,
Børge
hi i have one here if i was you i would change all the diodes for 11dq 10 then add a 5 volt super reg and change the opamps you will be very suprised how much better the cd player will sound
borges said:Hi,
Greetings,
Børge
A little more info on the chipset.
whats gan on said:a little bit of soap will wash away the lips stick from my face
Your cross dressing issues are no concern of ours.
I think that Beatstream conversion is not a problem in sound of your player.
Poor Clock section, simple and noisy power supply , generic analog section are the problems.
What DAC chipset uses DAD5?
whats gan on said:saa7321 dac saa7310 decoder
Same chips as Philips CD618/624/634/840/850 and similar to Rotel RCD865/965. QED Digit also used that DAC chip.
It is the first generation bitstream with the filter, dac, and analogue stage in one chip. The chip can be used just as a filter and the final internal opamps can be bypassed....but not the ones used for I/V. It has five 5V power pins.
The decoder is fairly common - found in many CDPs of that time. It is easy to access the I2S between the two chips.....but it would be nice to see someone having a real go at making something with 7321 sound better instead of just bypassing it completely.
Jean-Paul likes this chip and thinks it compares well to some of his TDA1541 machines. KWY hates it mainly because you cannot bypass all of the onboard opamps.
change power supply to the opamps
THE MISSION DAD5
with the opamps replaced with AD826an schottky diodes 11dq10
and pure silver wire bypass the two nikon bp caps creates a lot more life to my player it is so damn musical now with lots more detail. has any one powered the opamps on there own i would love to do that there is a -15 vot reg and a 5v + which i think powers the opamps
THE MISSION DAD5
Re: change power supply to the opamps
I haven't seen the circuit/schematics of the DAD5....but I would think that the +5V reg powers the DAC chip....and there should be a +15V reg and -15V reg for the opamps.
whats gan on said:THE MISSION DAD5
silver mica caps
just replaced 2 little surface mount caps with siver mica in the clock of my dad 5 and the sound is fast clean just like what would happen when you fit a trichord clock 4 any one know why they have made a huge improvement
Re: silver mica caps
Have you seen this thread?
Silver Micas for Clock in CD40
whats gan on said:just replaced 2 little surface mount caps with siver mica in the clock of my dad 5 and the sound is fast clean just like what would happen when you fit a trichord clock 4 any one know why they have made a huge improvement
- Digital Source
- Modifying the Mission DAD5
