A few points I think relevant but Forum didn´t let me add to my earlier post, so here they are.
Hope they add some extra clarity:
Yes, single turn coil will have 10000 times less inductance than a 100 turn one ... it will also have 10000 times less resistance (do the Math) .... inductance to resistance ratio will stay the same, go figure.
That´s why I said: "everything scales down" ... but keeping the proportions/ratio the same, it will also behave the same, same curves, everything.
If all ribbons are single turn and wound around the same core, and obviously connected in parallel and in phase, they are all "a single turn coil" meaning inductance will be the same.
No physical space for "more coils".
Just look at a few published impedance curves.
On voltage driven speakers, it reduces power reaching it, it´s a "crossover" series coil after all, but speakers have a rising measured response on axis, so both factors partially compensate and speakers end up having a roughly flat response up to 4 or 5 kHz (higher in small light ones) .
IF you current drive same speakers, they will show increased output at higher frequencies (also near resonance) which is used to advantage in Guitar speakers to provide desirable treble and bass boost.
a) your amplifier has enough current capability
b) your amplifier has enough voltage capability to push said current through that voice coil, which will always have some resistance and some impedance.
"Low" does not mean "zero" by any means.
10000 times less resistance and 10000 times less inductance means the inductance to resistance ratio remains exactly the same.
I´d go as far as suggesting 2 classics:
Acoustical engineering: Harry Ferdinand Olson: 9780193007048: Amazon.com: Books
Acoustics: Leo L. Beranek: 9780883184943: Amazon.com: Books
the first one is very rare and so expensive if you have to buy it, but both are readable in most University Libraries.
FWIW both were the core of what *I* studied at the Buenos Aires University Engineering Faculty in the early 70´s, go figure, and they are still valid.
Every single time I browse them, I find a new pearl of wisdom, a new exciting idea, how´s that?
So now you know where I´m coming from
skip the red clothes and the reindeer, but the white beard (and the paunch) fully apply
You can add: Sound System Engineering, Third Edition: Don Davis, Eugene Patronis: 9780240808307: Amazon.com: Books
not exactly focused on the raw loudspeaker itself but on how speaker systems behave in the Real World environment, outside the anechoic chamber, and so very useful.
This is the basic "old school" trio; there are many excellent and more modern books available, but all somehow rest on these giants shoulders, one way or another.
And again: "vanishing" does not mean zero.
performance will be the same as before, except for a scaled down impedance, resistance, reactance.
But resonance, curves, etc. will be the same.
350A RMS through your coil will definitely drop significant voltage across it.
And again: "almost" is not a number and definitely is not Zero, please do the Math using numbers, not labels.
Even a single turn will have inductance. FWIW even a straight wire has inductance.Still, a wide strand of copper ribbon should have much less inductance than a typical voice coil. Especially if it's only a few turns.
No.Could even run parallel layers of ribbon to reduce the inductance further.
Agree, since source impedance is infinite, by definition.Damping factor is irrelevant with current drive though.
No, see above paralleling in this case means nothing, what you will lower is DCR ... but there is a problem, there is VERY limited space inside the gap, so I already did my calculations assuming you fit maximum available amount of copper wire/ribbon there.Anyway, with a ribbon coil I can get the inductance down to arbitrarily low levels with parallel coils.
I already explained it, it increases impedance, typically above 400 to 1000Hz, and again typically doubling it around 8 or 10 kHz.What roll does inductance play in the response of the driver?
No, you can current drive any impedance speaker, as long as:If you read carefully, what I said was that there are advantages to current driver over voltage drive.
To use these advantages a driver needs to be ideally 0 ohms or close to it.
"Almost non existent" is a label, not a number.This method of voice coil also reduces the inductance and capacitance to almost non existent levels.
But you are asking about an electrodynamic driver hereI don't know how VC parasitics interact with overall driver response because dynamic driver tech has never interested me
Not a sin, unless left uncorrected, that´s why I warmly encourage you about reading about speaker principles theory.so I know little about it.
ALL you are talking about in this thread is dynamic drivers.I was talking about other driver tech. Not dynamic drivers. Read carefully.
Niot at all. Relative to speaker impedance it will be VERY significant.A flat strip of copper that is wide, thick, and short enough to be 100 miliohms or less over a few turns is naturally going to have vanishingly low reactance.
Plain answer: NO .I'm asking if the FR or performance characteristics would be superior to the typically used solutions.
Oh yes they will.the voltage axis of device transfer curves almost do not come into play.
Yeah, I was wondering about that. That's why I asked what the relationship between VC parasitics and driver performance was. Wasn't sure if it was that simple.A few points I think relevant but Forum didn´t let me add to my earlier post, so here they are.
Hmmm, not sure I understand that one. If I split a 4 turn coil into 4 single turns in parallel wouldn't that reduce the inductance 4 fold while maintaining the effective turns ratio?No.
I was referring to my statement that if you drive a near zero ohm load, the electrical system will become more linear in certain aspects due to the lack of voltage swing required.No, you can current drive any impedance speaker, as long as:
IMO a near zero ohm load using current drive removes a number of problems with minimal tradeoff. Assuming the load is suitable to current drive.
I'll check those out. ThanksI´d go as far as suggesting 2 classics:
Yeah well, I certainly won't be building an amplifier capable of putting out 350A so that kills the idea anyway.350A RMS through your coil will definitely drop significant voltage across it.
The entire idea hinged on the current requirement being not too far off from the typical driver requirement.
You've cleared that up for me.
I'll stick to other driver technologies that are more conducive to lower currents.
