Modify Parapix Bass Boost Gain
Hi everyone,
I'm planning on building a set of sealed subwoofers using Peerless SLS 10" drivers and a pair of Parapix Subwoofer Amplifiers.
The Parapix amps use two LM3886 chips, which can be bridged to get 120w into 8 ohms. They also come with a bass boost, which entails a 12dB boost at 33.5Hz. More info on the amplifier here: ParaPix Subwoofer Amp Info
The amplifier schematic is here: http://i.imgur.com/v2Wbh94.gif
I'd like to modify the gain of the bass boost function to around 6dB (half). This is a much better number and models really well in WinISD with the SLS driver.
Any ideas on which components to change to yield a lower gain?
Thanks in advance.
Chris
