Modified Windows Media Player Plug-in
HOW TO CREATE A WEB PAGE WITH MODIFIED WINDOWS MEDIA PLAYER PLUG-IN
THIS IS A MODIFIED VERSION OF A NEWER WINDOWS MEDIA PLAYER PLUG-IN SCRIPT
WITH AUTOSTART AND AN ADDITIONAL "LOOP" (REPEAT) FUNCTION AND THE MEDIA FILES WILL
CONTINUOUSLY REPLAY AUTOMATICALLY. IT WILL PLAY BOTH AUDIO AND VIDEO FILES OF A
COMPATIBLE TYPE.
CREATE A STANDARD HTML WEB PAGE WITH .htm FILENAME EXTENSION BY COPYING AND PASTING THE FOLLOWING FROM <BODY> TO </BODY> HEADERS INTO A TEXT EDITOR SUCH AS NOTEPAD AND "SAVE AS" WITH AN APPROPRIATE FILENAME AND FILENAME EXTENSION (e.g. playlist.htm).
NOTE: THE FOLLOWING IS TO BE CREATED AS AN INDIVIDUAL SEPARATE FILE.
WHERE "playlist.wpl" IS SHOWN (AFTER VALUE= AND SRC= SAME CAN BE RENAMED TO WHATEVER IS APPROPRIATE (.e.g. "myplaylist.wpl").
<BODY>
<p align="center">
<OBJECT ID="MediaPlayer1" width=352 height=67
classid="CLSID:22D6F312-B0F6-11D0-94AB-0080C74C7E95"
CODEBASE="http://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cab#Version=6,4,5,715"
standby="Loading Microsoft Windows Media Player components..."
type="application/x-oleobject">
<PARAM NAME="AutoStart" VALUE="True">
<PARAM NAME="Loop" VALUE="True">
<PARAM NAME="FileName" VALUE="playlist.wpl">
<PARAM NAME="ShowControls" VALUE="True">
<PARAM NAME="ShowStatusBar" VALUE="True">
<EMBED type="application/x-mplayer2"
pluginspage="http://www.microsoft.com/Windows/MediaPlayer/"
SRC="playlist.wpl"
name="MediaPlayer1"
width=352
height=67
autostart=1
loop=1
showcontrols=1>
</EMBED>
</OBJECT></p>
</BODY>
IMPORTANT! BE CERTAIN THAT THE playlist.wpl FILENAME MATCHES THAT OF THE MEDIA PLAYER.
HINT: THE WIDTH AND HEIGHT AS SHOWN ARE: width=352 height=67 FOR AN AUDIO FILE. THIS MEDIA PLAYER SIZE CAN BE RESET TO 'DEFAULT' OF width=352 height=288 OR RESIZED AS DESIRED TO ALSO PLAY A COMPATIBLE VIDEO FILE.
CREATE A STANDARD PLAYLIST FILE WITH .wpl FILENAME EXTENSION BY COPYING AND PASTING THE FOLLOWING INTO A TEXT EDITOR SUCH AS NOTEPAD AND "SAVE AS" WITH AN APPROPRIATE FILENAME BETWEEN THE <title> and </title> HEADERS AND FILENAME WITH FILENAME EXTENSION FOR THE FILE ITSELF (e.g. playlist.wpl).
<?wpl version="1.0"?>
<smil>
<head>
<title>playlist</title>
</head>
<body>
<seq>
<media src="song1.mid"/>
<media src="song2.mid"/>
<media src="song3.mid"/>
</seq>
</body>
</smil>
REPLACE THE "SONG.MID" FILE NAME IN EACH INSTANCE WITH THE DESIRED MEDIA FILE TO BE PLAYED. THIS SAME MEDIA FILE CAN BE ANY ONE THAT IS COMPATIBLE WITH THIS MEDIA PLAYER (e.g. "song.mp3", "movie.wmv" and etc...).
IMPORTANT! BE SURE TO SAVE ALL MEDIA FILES, THE HTML WEB PAGE AND PLAYLIST FILE IN THE SAME FOLDER OR ROOT DIRECTORY. A FOLDER CAN BE CREATED AND THEN THESE SAME FILES ADDED TO IT FOR REFERENCE (e.g. Folder Name: playlist).
