modding Yamaha NS-150. Measuring small-thiele parameters & new crossover
Hi!!
I want to improve my 3-way speakers since I damaged the tweeter of one of them.
I opened the speakers enclosure and I was so disapointed with the crossover 😡
Electrolitic capacitors and small inductors.
So I decided to do some improvements to the speaker system:
- [DONE] change both tweeters (dome) with new ones (Audax TW010F1) . Since the audax tweeter is not a silk dome like the originals, i have to upper a little the second crossover frequency.
- build an entire new crossover network, with decent inductors and capacitors
I started looking for the small/thielle parameters for each driver but I was unable to find them. So I decided to measure them using this guide:
http://sound.westhost.com/tsp.htm
I got the Fs, but I cannot continue measuring because I dont know what is Is, and the page didnt says.
So, if anyone can help me, I have a few questions.
1- what is "Is"? (look at the excel screenshot)
2- what do you think about the driver?
3- both "subwoofer" and "mid" are the same driver. Is that OK ??
some pics
hello.
holiday...............sitting in the garden (and drinking water or so)........
i am no speaker expert,but
have a look at figure 6 in the text.................
rs = 10 ohm
vref = voltage drop in the linear region above resonant frequency fs (in your diagram around 200.......300Hz; and between 10 and 20Hz)
and Is should be vref/rs (by ohm's law).
the driver has a high fs for a woofer...............no real "deep bass" if your measurement is well done.
looks like this is an "two and a half way sytem" (woofer and woofer-midrange).
have you drawn a schematic of the original network?
perhaps you do not need all this parameters because you have a box with it's speakers - so you only need to upgrade the parts and adapt the network for the tweeter................
greetings...............
mjf said:
hello.
rs = 10 ohm
thank you very much, I've figured out how to do it.
I have a new question.
I want to connect a zobel network in the speaker, but according to this page http://sound.westhost.com/lr-passive.htm I have to know the inductance of the voice coil, wich I dont know. Using the excel spreadsheet I know the RLC parallel values of R, L and C, but I dont know the R and L series (I supose that L series is what I need)
my question is how to find the L series, and if it is the one that should I use for the calc of the zobel network.
thanks!!!
hello.
there is annother way to determine a rc network to compensate the increasing impedance in the upper frequency region.........
by experiment and measuring:
first measure the coil res (rvc) with a dmm(ohmmeter).
r in the zobel network should be around 50% bigger than rvc:
r = 1,5 x rvc
(powerrating a few watt).
and second try to find a cap that makes the impedance flat........
i would begin with 10uf (non polar elco) in your case.
build the network onto the speaker and measure the impedance........
change the value of the cap a little bit if it does not fit to find the flattest impedance curve............
