Is it worth to build a new digitalout on a Pioneer PDS904,any suggestions on a schema that will outperform the original digitalout?I read that Elso Kwak had done a schema on one,is it god?🙄
Get a Tentlabs XO3 clock and you'll improve the sound and as a bonus you'll get a far better coax spidf digital output as well.
Cheers George
Cheers George
Thanks for the suggestion georgehifi,but I am giong to put in a clock made by Kwak..I thougt if there was a schema of a god output to build.🙂
I would use this: (infact I already have, with that very same player)
The Spdif out of the CXD2500 is however not very good, I suggest you use one of elfas last CS8402:s to make spdif out of the regular data/timing outputs instead.
