Hi!
Well, this is what's up: i have at home an old relic radio/LP player, from 1956 that was my grandfather's. It uses an EL84 in SE mode for output, together with a lot more tubes. It's a Siemens, but don't know the model right now.
I would like to know if it is possible to add a line in jack or something that would do the trick, without harming this little wonder, so that i can play my cd's on it thru a cd/md player.
Any sugestions?
Many thanks!
Any sugestions?
Many thanks!
Petman,
First of all, make sure the chassis is not live. It should not be (by design), as it uses the "E" series valves.
The problem is that safety standards were not good at the time of manufacture. If not already fitted, you may have to change to a 3 wire mains lead, and earth the chassis.
If that can be done, then just intercept the lead to the top of the volume control with your jack, take the shield connection of your jack to the bottom of the volume control.
Please be careful to keep your signal wiring away from live or hot components.
Quaint CD
Of course it's possible. I assume that you are more concerned with the quaintness of the idea than the sound quality. The hardened old radio fanatics fit a modulator onto their CD player so that they can actually tune in to the CD player! (No, I don't have a diagram.) The alternative is to get at the selector switch and find the screened lead that goes to the pick-up arm, chop it, and connect it to a pair of phono sockets. Job done!
OK you will lose the record player, but, believe me you wouldn't want to let it loose on your records...
Ok, let see if i got it right: I'll use the vol control line out to the power tube as the input for the player, like a regular tube amp, right? Now, if i make it to just have no selection from radio and LP inputs...
I don't want to screw up this radio, as i have a few (ok one) LP of mine from Jean Michel Jarre that sounds great, and my mom has a lot of old records that bring her back to the youth days. And the sound is absolutely fabulous! The bass is clear and strong, the treble good and with a low volume, if i just get my hand close to the speaker the air vibes! It's something i never felt in any other type of amp (all SS).
BTW, any hints on how to get the hum out of it? is anoying at low volume....
Many thanks guys!
Many thanks guys!
I looked a bit more to the plug and it seems to be a 5 pin DIN, 4 holes around it and one in the middle. only 2 pins have contacts.. Maybe it's better to open it up a bit to see where the wires go.
BTW any thoughts on it's value? Not that i want to sell it.... just to have an idea as a collector's item.
Thanks!
Thanks!
Petman,
If only 2 pins are wired, then you only need to determine which is ground. This can be done with a meter.
The value will depend on condition and rarity.
I don't know this model, but generally speaking:
If it is's cabinet is made of bakelite, an ealy plastic, often brown, then it will probably be worth more than wood. If it a bright colour, then more still.
You may be able to find out more by searching by model number. I'm sure someone will have resored another, and published details.
If you open and clean it, take great care with the dial glass. Only clean with a soft cloth, and clean water if you must. The markings often just wipe off.
Here's a pic:
http://users.skynet.be/albert.aerts/radio/pages/siemk65.htm
Not exactly the same as pictured, but very similar.
Thanks!
Thanks!
- Tubes / Valves
- Mod to an old radio
