Hi Mooly,
Thanks for the reply & the feedback.
I only hear the clicking sound when I’m near the DAC. I don’t hear them thru’ the headphone that’s connected to the DAC. I don’t recall hearing this clicking sound when my DAC is connected to a DVD player that has got a built-in coaxial digital output.
I think there’s some kind of latching going on, on the board inside the DAC.
I guess I’ll go ahead & mod the Kwak clock on my CD player while leaving this circuit (TTL to SPDIF) on my LD player.
You mean the DAC itself clicks ? not clicking on the audio output. That has to be a relay/s, nothing else would do that. The DAC perhaps does mute when it detects no "audio" in the data stream.
I suspect that although the resistors are in series, they do give an effective output impedance of 75 ohms, which is the correct impedance for S/PDIF coax.
As for the clock stuff... whatever oils your snake. 🙂 I'd expect most DACs from the last decade or so should have some anti-jitter stuff built-in, like an ASRC (asynchronous sample-rate converter) (like that nice chip AD made that also acted as an S/PDIF receiver).
🙂 Mea culpa
Never played around with clocks. I always feel the idea is sound, but could be let down in the implementation. If the new clock ends up a few centimeters away from its destination the overall result could be worse. Correct grounding of all the relevant parts that make it up become important to.
