Mmats dhc 1400.1
Hi all,
Amp came dead. No outputs were bad no power supply fets were bad.
Powered up and was pulling 0.4amps. Checked pin1 voltage which was 5.2v and pin 2 was 5.1v. So I removed the outputs and same issue. I removed main rectifiers same issue.
Removed 4080 same issue.
I lifted the voltage divider resistors connected to pin1 with main rectifiers on board and without 4080 and outputs. Amp came on with 1.3Amps stable. Tried to remove the current limiting resistor and it went upto 4.5amps. Main rail voltage from which voltage divider is connected to go to pin 1 of sg3525 is 87v. Is that current draw normal. And what is the pot in the middle of the board use for?
