Mmats d3500.1 questions for repair
Pin 15 is not obtaining it's voltage out of thin air. Are you visually obtaining it's connection point? Or walking the PCB out with your meter?
I have not worked on one of these but multi-layer boards are a thing in car audio. My experience is with the older generations of these amps and the Earthquake D3. Which is close but my attempts to determine how close in this thread are hit or miss. You mentioned it's more like the Fusion but the Fusion schematic I have here uses a 494 not a 3525. My ability to walk you through this has become limited. You need to find the voltage source for this pin and determine why it has voltage with no remote applied.
He was referencing the bridge rectifier and voltage regulator for the fusion. The earthquake is deffinately way closer. I have continuity between pin 13 and pin 15 of the sg3525. So it's getting voltage how I explained. I visually inspect motherboards then check and double check with dmm. I also use a flashlight from the other side of the board for some of the not so obvious stuff.
Without a valid schematic or the board in front of me I can't help you trace the circuit out. I can only tell you what direction to go. Based on the voltages you posted I suspect a component leaking B+ into the remote line. I know you feel it's designed this way. But I can't recall every seeing an amplifier with constant power where it's being displayed. This is the best I can do from here with what I have to work with.
If you want to post a CLEAR photo of the entire BOTTOM of the PCB and the entire TOP (One of your photos was blurry) then I or someone else may be able to visually follow the line. Perry may have some valuable suggestions as well.
It definitely is in the speaker as well. Gain or frequency does not change it nor does putting pressure on any part.i have not tries heating any parts but I can. The only thing I found that affects it is input voltage higher voltage is louder noise.however I do have 3 fets out of the amp. It's the right toroid making noise not the left.
Without a valid schematic or the board in front of me I can't help you trace the circuit out. I can only tell you what direction to go. Based on the voltages you posted I suspect a component leaking B+ into the remote line. I know you feel it's designed this way. But I can't recall every seeing an amplifier with constant power where it's being displayed. This is the best I can do from here with what I have to work with. If you want to post a CLEAR photo of the entire BOTTOM of the PCB and the entire TOP (One of your photos was blurry) then I or someone else may be able to visually follow the line. Perry may have some valuable suggestions as well.
Thank you this info helped me tremendously.
