Mmats 4000.1D
Hi all
The above mentioned amp blew all the power fets and half of outputs. I fixed the amp and again customer returned blowing the power supply. On observation without output fets the amp comes on but with 3% duty cycle when the voltage is 12.5v. When I reduce the voltage to 10v then I am getting good 45% duty cycle and it pulls about 0.6amps current. Is this have to do with repeating power supply damage?thank you.
Forgot images. Now attached
