I am in in process of building a few MM phono preamps and I would like to know what type of capacitor is best for capacitance loading. I will start with the standard 100pf value but should I use ceramic, mica, polyethylene or polypropylene capacitors. I may use jumpers to switch values for tuning. Thankyou for any suggestions.
Polystyrene and polypropylene would work well. You should know series inductance and series resistance of the cartridge, and cable capacitance. Then, when loaded by 47k you have to tune additional load capacitance for overall flat response. You may find that usual 47k is not necessarily the best value for resonance peak damping.
Thank you for your response. Could I add the additional load capacitance via a polycarbonate variable capacitor (5 to 100pf) and the resistive loading with a 100 ohm multi-turn cermet trimming potentiometer. You could adjust both to fine tune the entire setup.
Sure you can.
For a jump start you could search for the cartridge manufacturers recommendation for the capacitance (different for every MM) and begin from there.
Hannes
Hannes
Value is FAR more important than the plastic film type. PP, PC, PS will all work fine. The issue for some MMs is often that there's already too much capacitance in the interconnects/preamp.
Even worse - usually the capacitance of the interconnects coming out of the turntable is completely unknown. Perfectioniados replace them with something better suited and get rid of the regularly crappy connectors as well at the same time.
Hannes
Morgan Jones who recently wrote one of the best books on this subject recommended using a tuning condenser out of an old radio, that might be 300pF when closed, and to adjust it while playing some kind of test record that shows the upper end of the response (pink noise?). Then you'd be taking into account the capacitance of the tonearm wiring and interconnect cables too. This is because of how critical the value is. It's forming a resonance with the self inductance of the particular cartridge, to cause an extension of a frequency response that otherwise rolls off prematurely. So it's important to get it exactly right.
I tried measuring the capacitance of my connecting leads. The capacitors I tested were 1.2nf and 47 pf with my DMM with the setting at 2nf. These read at 1.155nf and 0.051nf respectively. My leads were not readable on their own, the DMM gave an open circuit reading. The leads in series with the capacitors did not change the value obtained for the capacitors. Am I doing something wrong as I am unable to read any capacitance values for any of the leads. But then leads are not capacitors.
At audio frequencies your lead is almost a pure capacitor. Unfortunately most meters expect the capacitance between the leads to be much larger than from either of the leads to ground. The lead has substantial capacitance from the shield to ground
Can you remove the test leads from the meter?
Can you somehow insert the smaller capacitor directly into the meter's sockets?
If so you can subtract this reading from the reading with the test leads to find the capacitance of the test leads.
But this difference reading will change with how you dress the leads.
I may have found my problem by reading through forum posts. I believe that I need to connect the positive and negative of one end on the cable to my DMM. I was trying to measure positive to positive ends of the cable.
I will measure the cable unconnected and then connected to the turntable (Project Expression) and then connected to the phono preamp. 😕
Finally I can measure the capacitance of my connecting leads. My 30cm shielded gold plated economy cable measured at 160pf. However the basic cheap 1 meter dual cable measured at 110pf. My Ortofon 2M red requires 150 to 300 pf. So when you add in the capacitance of the tonearm cable, I should not need any additional capacitance in my phono preamp.
Some current cartridges from the Shure range need just 250pF ! That is really tough with ordinary cables and connectors unless you have the shortest possible leads or install the phono pre in the turntable case.
I have some Denon test discs that have frequency sweep etc. on them. I tried using them long ago but used to have issues with the LF resonsnance of the arm/cartridge causing the output to fluctuate quite a bit.
The Jap magazines used to have lots of information on cartridge and capacitance/resistance loading with response plots. I had those articles for a very long time and used to look at them ocassionally. I tried to find them but have been unsuccessful. I don't throw away such things and am hoping that it hasn't got lost somewhere. They would come in very handy right now. There was a great one on the effect of fluid damping on tone arms too.
Wouldn't some of our Japanese members have access to their old mags ? ( these must have been from the mid or late 70's )
Are you sure? Relatively high capacitance coax like RG-58 (solid dielectric 50R) is 100pF/m
Yes according to my DMM the capacitance is 160 pf for the 45 cm cable (not 30). DMM is Digitech QM-1324 with two short wires inserted into Cx to allow measurement of cables and capacitors with large widths.
Inter-windiing capacitance in MM cartridges
This is an old post -- hope somebody notices this reply 🙂
I wanted to point out one thing fact that I don't think I've ever
seen mentioned about cartridge loading. All those turns of wire in
the MM cartridge coils create what is called inter-winding capacitance.
This is (in MM carts) a significant capacitance, effectively connected
across the coil and it is in parallel with the tonearm wiring and
cable capacitance.
For example, I've measured the impedance (for those engineers out there,
complex impedance -- resitance and reactance) of my Ortofon OM Super 20
MM cartridge. This measurement included tonearm wiring but no other cables
were connected. I don't think the tonearm wiring would have added more than
10pF of capacitance to the results.
The advertised resistance is 1000 ohms and in fact it is 1040 ohms. Very
close. The advertised inductance is 580mH and I came up with 510mH. Still
not that far off.
Manufacturers don't advertise inter-winding capacitance;
I measured about 108pF of it (this includes tonearm wiring,
so perhaps the actual value is closer to 100pF or so). This creates a
self resonant frequency around 22-23kHz -- and that's with no capacitive
loading from cables or preamps. When the manufacturers suggest a load
capacitance, this is in addition to inter-winding capacitance.
Another thing they don't tell you about is losses that occur in the magnetic
structures of the cartridge. This appears as a "ghost" resistor in parallel
with the cartridge -- 191k-ohms in my case for the OM Super 20.
A very accurate electrical model of my Ortofon cartridge impedance
turns out to contain three components in parallel with each other:
1) A 510mH inductor in series with a 1040 ohm resistor
2) A 108pF capacitor (includes tonearm wiring, probably < 10pF)
3) A 191k-ohm resistor
I'm sure at this point, you non-technical folks' eyes are starting to
glaze over. Here's the bottom line -- it is difficult at best to
figure out proper MM cartridge loading with only the data published by
manufacturers. You either need a test record or some amount of trial and
error with subjective listening to get it right.
In the end, this process lead me to mount
my home-made preamp under the turn-table -- soldered directly to the
tonearm wiring to minimize capacitance. I used a 90k-ohm load resistance and
zero added capacitance. This results in a very good theoretical response
to 20kHz.
There's still something missing from this -- I don't own any test records
and there could still be problems in the stylus/cantilever system that
would cause a non-flat frequency response. On the other hand, I like the
resulting sound so that's going to have to be good enough for me.
Hope you find this useful!
cable capacitance.
not that far off.
to 20kHz.
- Analog Line Level
- MM cartridge capacitance loading
