Originally posted by critofur So again, I ask, assuming standing waves are not an issue, what other benefits might be had from a TL?
Minimally, you eliminate the driver's rear wave so at least it does not cancel with the driver's forward output. More ambitiously, you can harness the cabinet's fundamental resonance to create a standing wave that sums nicely with the driver's forward radiation to create greater LF output.
Whereas standing waves are a sort of "defect" for a "pure" BR (if a BR is idealized as the resonance of two masses of air without taking cab dims into account), standing waves are an essential feature of a quarter-wave cab. Or at least the fundamental is a feature -- the higher harmonics cause peaks and nulls when summed with the driver's forward output, and thus need to be minimized. Or something like that...
critofur said:Well, that's not at all what I do - I place a sheet of a special damping material in certain points in the box which breakup the standing wave without being too restrictive to reduce bass output.
1st off it is not possible to kill all the standing waves with that damping strategy.
A well designed TL will be much more tolerant of the change of T/S parameters as the drive is changed because the qw resonance is dominant. A traditional BR will go in and out of tune as the volume changes, particularily annoying if the music is particularily dynamic.
dave
because of the taper on a ML TQWT, roughly what percentage extra does the line length need to be, around 10% ? (obv depending on the flair)
