MLTL 206 Filter components
Trying to fine tune my MK MLTL Fostex 206, I now using Madisound Sledgehammer 3.0mH inductor, would the perfect lay type or Goertz type be an improvement? Using a Multicap 4.0uf film and aluminum cap, any suggestions? Tried a 3.0 Hovland and Auricap. A 4.5 ohm parallel resistor seems to give me the best balance. Thanks in advance.
I am using 1,8 mH and 8 ohm in a ML TL wih the FE 167 E
no caps at all !!!!
Do you have pictures and drawings of the enclosure
Fostex 206E
The cabinet plans can be found at Martin King's MLTL website. I am surprised at the difference in filter network components being used by the readers. I started with the recommended filter by M.King and modified it slightly. Are you guys using the same cabinet parameters?
