excuse me...what?????? No one asked for any hand holding. And guessing what a problem is (your first contribution) or making idle unrelated comments is not learning anything or helping anyone.
I am puzzled why you found a need to make this comment and one that is snotty, tacky, and rude...if your serious about learning. You found this to be helpful? Who do you think you are?
I have been in electronics for 35 years...do I know it all, NO...either do you. Isn't THAT what this forum is for? So, tell me just how you have helped.
Do me a favor and refrain from helping.
DF96 may have some helpful critical points, maybe not. But I would not trash someone's amp in the process of commenting, suggesting good parts are not worth putting in this amp. Do I find oddities in the design...yes I do, but Randell Smith is not an idiot, nor are his engineers.
So, what is this site, a gentlemans club, dishing club, or a fight club? It costs nothing to have manners in a gentleman's club or fight club.
I think I shall look elsewhere for some ideas.
For all to see I will add, not just on this topic thread, but on many I see that the real subject wanders off and folks start getting judgemental and darn offensive with replies just as one sees on political blogs. I use to read some very well informed and technically detailed replies from members on this site and other sites, but they don't post or rarely post anymore....I was about to join them.
I was hoping to see names like Eva, gootee, conrad hoffman, and some others join in on this topic. These folks know alot about caps, power supplies, and applications and use technical details to support their posts.
So, I will try to get this train back on tract with my original question: has anyone used DC-Link caps in a power supply of a tube amp.
If one sorts out all the posts here, the secondary question emerges....why does this amp sing like a prized canary in every setting but not in full 'all out' pentode? This is the root of this topic thread. What is going on in pentode.
If this amp sounds like a jaw dropping champ to folks who have heard it in triode and triode-2/3 pentode mix, why would the phase inverters and drivers tubes suddenly be the culpret? Are two more tubes in pentode vs triode (at 3/3 pentode) more than the 12ax7s can handle? Maybe, but if there is a post to that affect, some details on the how and why should back back that position up. It does not matter if 6L6, 5881, el34, kt66, kt88 or any other tubes (vintage or new issue) this amp is able to run, in pentode there is a grainy presence. This 'grainieness' is less so with vintage tubes, which again brings me back to the screens which new tubes can have a problem vs old ones. If you had a battery radio, and the batteries were loosing steam, the grainy strain heard on the speaker is in this neighborhood.
Why not poor or inadiquate screen control...regulation or to low capacitive reserve power supply for pentode? To me, seeing a pair of 47uf caps in series (making what 23uf) seems very shy for the task of screen control of six tubes. I see old Fisher, Scott, Mc's and many more that used a full 47 to control the screen and sometimes screen stoppers as well on just two tubes. I have already pointed out that, to me, 800uf supply for the B+ seems shy for power in the pentode mode.
I would like to read comments on this pentode/screen point before even thinking of someother part of this amp as being suspect. The horse does not have a broken leg, it just doen't like playing hard rock or heavy metal....yet.
Probably more unwanted comments, but...
[1] Since your "stack of electrolytics" is not directly providing power to the six-pack of pentodes, any (very slight) differences in audio-band ESR between them and a creative, oversized stack of film caps ... is going to be invisible to your amp. And ears.
[2] You may find though, after the "replace-the-caps" activity, that your amp will sound rich and beautiful and wonderful in ways that you hadn't heard before. Since you can't "A/B" test the PS mod (it would be remarkably unwieldy to do so) ... the Pride of Completion of a Theory Put Into Practice factor will be coloring your opinion. Its OK! We all have it!
[3] The comments by DF96 and others regarding the "candidate for most inappropriate use of the 12AX7" is candid, valid, and from my read of the schematics, entirely justified. On one hand, I'm amazed you get good sound out of the amplifier. On the other hand, there's enough gain through the various component chains that I understand why the amp actually performs as it is claimed to do.
[4] Th question of poor or "inadequate" screen control is a bit of a canard: you say the amp sounds great. Why bother questioning adequacy of a 24 µF cap (equiv) at doing the job, when it is doing the job apparently quite nicely?
In short, you asked, "what do y'all think of my substituting film caps for a stack of electrolytics?" We looked at the design, and with various attribution, we came up with "why?" and "gee, that's an odd design", and "though off-topic, these tubes would be better" and "use parallel HV caps, if you're going to make a substitution".
My own opinion is similar, with an added caveat: Use a small-value high-voltage insulated choke leading to your caps from the rectifier bridge. Rectifier, choke, caps.. The choke's value should be around 0.1 to 0.5 H. Non critical. The effect of this little helper is to radially (3-4 orders of magnitude) reduce switching tank oscillation. This will be especially useful if you go all out and buy a couple of hundred dollars worth of film caps. Further, if you decide the "film cap experiment" was doomed for some other reason, and you aim to restore the elecrolytics ... the little choke still will deliver good results.
So there you are. An modest opinion, amongst my betters.
GoatGuy
GoatGuy
Hi Goat Guy,
Thank you for all that. Appreciated, and understood....
#1) but not exactly this: Since your "stack of electrolytics" is not directly providing power to the six-pack of pentodes I do get that the ERS may not have much of a difference. Impedance may be a different story for the ears. But power to the six-pack, what do you mean, please?
#2) yes in search of the holly grail is the main reason I was considering MKP film if I have to redo (atleast part of) this supply. I have done MKP in small amps, vintage amps, guitar amps and yep...it is a eye opener hands down and you suddenly understand that music does pass into, through, and out of the power supply and all the colorations tag along in an endless round and round cycle. Bit like thinking your in love vs knowing you are, or a single day that is so crystal clear that the sunlight is like nothing you have seen before.
Your item #3 is just how I look at it, but it is 'apparantly' doing a good job and I hesitate altering it unless I can be convinced that is the source of the pentode issue and it won't change was the amp is doing right in triode.
#4) Again, the amp sounds wonderful [U]except in full pentode[/U] and maybe hinting grain in 2/3 pentode. The screens are not in the circuit except in pentode. Otherwise the screens are tied to the plate ( the switch may appear as in a 'no state' position, but the switch is either locked in triode or pentode. So, I do not know if the cap is adequately doing it's job in pentode...that is my question. I suppose I can up that and see if it begins to solve the grainy artifact.
Yep, the idea of yanking the power supply out and redoing it with big fat parts and the associated 'murphy's law' surprises, logistics, etc., is a serious matter that must be weighed...and not by whim. Even subbing one or two higher uf and vdc value caps for the 4700@100, means taking out the supply board...a matter of nothing fits in this shallow chassis ( the transformer bells are under the board)
I will look at the choke idea, I don't think I have any that small of a value (I'll see what Hammond or Erse has), but I think you have hit on the most simple idea for a first attack, and maybe saved the last two hairs on my head.
Thanks...and glad you took time to put in your modest opinion!
hi folks, i have used many times vishay DC link MKP in my tube amp .
and they work very well, in fact they have so low ESR and are so fast that sometimes i prefer a good old film in oil for the power supply and keep the Vishay DC for cathode bypass.. the big advantage here is their size... 🙂
Hi Juanitox,
are you refering to the box style DC Link and not the round? I was ??? the box style because of the tight corners and long sides and how the film would behave. They are hard to find in the USA.
yep, that is it. They are not in the USA yet. Farnell UK has just started to stock them but not Newark USA.
Thank you for the input.
As others have said, my comments have merit (in the sense that they are technically true, if unpalatable) and are constructive (in the sense that I am giving you good advice not to waste your money on 'upgrading' a poor circuit). Like most people on here, I attach little weight to magazine reviews as I have too often seen bad designs (often with weak performance) praised to the skies.glassandlight said:I welcome ideas and suggestions that are constructive and have merit. If you comments and or ideas have such, then print them for others to review and consider as a solution. But throwing rocks does not seem correct for these forums.
I despair at the high number of commercial amps with basic design errors. This is primarily a technical forum, so technical comments should not be a surprise.
I'm sorry for hurting your feelings. I'm out.
Thank you DF96. Thank you for being a gentleman. And, I am sorry for wearing my sensitivity on my shirt cuffs, I should not take such comments to heart. I do not think anyone here means to hurt anyone.
Sometimes I think reading something on a computer screen transulates differently than on paper.
None of us want to feel like we bought a pig-in-a polk. And, indeed, we have all seen some dumb designs or at least questionable ones based on what we know.
It was not that I did not welcome your ideas. The contrary is I do, so does everyone else. If this amp did not have a problem that I am not able to see, I would not be posting and seeking answers.
I would welcome you input and suggestions. Do you think the drivers and phase splitters as designed here are causing the grain/strain in only the pentode mode but not in the triode mode? How would you do it differently?
My suggestion is look at building your self a new amp from a clean sheet of paper then compare it to the baron . With help of many here you can have a much better sounding amp and then sell off the baron rather than fix it. That is some of the fun found on this web site and hobby.
MY GOD brilliant!!!!!!
as one fanitic DIY to another fanitic DIY...I feel blessed by you suggestion.
Thank you, tears come to my eyes!!!! Such a wise answer from the field, thank you seems so meaningless here. Thank you, thank you, thank you, I say....I shall light a candle next week for you...... thank you, thank you ,thank you!!!!!!! Bless you for your contribution!!!!
and, so....I post soon an answer from a pal who wrote to his pal (calling in chips...you know, asking a pal because you are not completly sure you are in the right field but don't want to ask to get something for nothing) who is one of the most repected amp designers in the world for tubes.....want to know who posted what and was hitting on the target??? Stay tuned !
One or two of you were kissing close !!!! but the target keeps getting in the way. The answer is so simple that it was in the conversation all the time !...did we see it and were the sailing ships from Spain sailing into the new world, who's people never saw a ship like that and simply said "it is not there, so I do not see it".
Is this a quest for answers not easy? Yes?
PS: to whom shall I sell an amp that has kissed my heart and soul?
I don't understand the meaning of post #34, but in general I would say that if you respect the designer of the amp and like how it plays, for safety reasons recap the thing with plain elco's closest to the spec you've got there now, close it and start enjoying it again. Never put it back to 2/3 pentode mode: triodes are the best anyway, not even the best designer can make a pentode sound like a triode! And if 6 triode wired KT88's in PP don't make enough power, it is probably a mismatch with the speakers you are dealing with - hey, I am not saying the speakers are badly designed! just that some speakers need enormous power or very high damping factor to play their best. And ignore this list. If you think you haven't been treated well here, you can always write around how a bunch of amateurs the diyaudio members are, even daring to challenge the wisdom of respected designers - but I would just forget all this just as a you forget a nightmare- and move on enjoying the Baron!
My best regards, Erik
Greetings Erik,
what you have written is just about what the personal email from TP says. Who is TP? I was asked not to post his name, but he is one of the world's most respected names in tube audio and now lives on the West coast doing a little joint venture with another audio designer.
His email to me is very much what you have written....and ignore the list too, he says. "How can someone say the circuit is bad if they have never heard this amp?" "Who are these people?"
His answer is also along the thinking of TOMCHR, post #5..."What's the B+ voltage of this amp? 500 V? If that's the case, I suggest getting two 2200 uF caps rated for 350~400 V operation and connecting them in series. That should take up less space than the current configuration and would leave room for a good polypropylene cap to be connected in parallel with the electrolytic cap., except he recommends doubling the uf for the B+ and 220 minimum for the screens. He knows this amp and has heard it, and feels the supply is fine for triode and part pentode, but starved in full pentode and not enough regulation for the screens.
He also agreed that a small choke after the hexfreds is a reasonable idea to consider " it can't hurt if it is small and right voltage/amperage"...so GOATGUY had a good suggestion in post #25.
So the last thank you goes to JUANITOX in post #27, the only member who answered the original question...has anyone used DC Link caps.
Should any Baron owner stumble across this topic and thread, the answer has now been posted as to why the pentode mode has a grainy edge, at better than moderate volume anyway. Boost the uf in the power supply to raise the headroom, and enjoy one of the best sounding amps ever made.
That's it....I post no more to this topic.
1. By reading the circuit diagram; a skill that even some 'designers' seem not to have acquired. Like literacy, reading circuits is a necessary precursor to creating good circuits. Good circuits are necessary, although not sufficient, for faithful sound reproduction.TP said:"How can someone say the circuit is bad if they have never heard this amp?" "Who are these people?"
2. A retired physicist/engineer, with 45 years experience of DIY RF and audio electronics.
I wasn't going to re-post in this thread but I felt that your friend's questions deserved a reply.
Sarcasm is not your Forte . My I suggest what I say at Tractor Supply on a t-shirt " Stop your winning put on your big girl boots and get to it" As a side note a baron in on ebay right now for sale bid are at 600 dollars 2 day left hurry now. There are many fine books on power supply design dating back to radiotron handbook that should be read and understood before undertaking playing with high voltage it by the way can be lethal ( and not in a good way). Good luck with this have a good day.
If you could get one of those Barons for $600.0 it would be a steal. A sextet of triode connected 6L6's per channel and big output transformer just by default has got to sound pretty good. I'm tempted caus' it's definately a well made amp and it would be much fun to play with that circuit.
- Design & Build
- Parts
- MKP DC-LINK vs electrolytic power supply 4 tube amp
