Re: Re: MKP caps: are these for real?
I'm even dafter. I used to plug selenium rectifiers into the power outlets at school as an incredibly effective stink bomb.
Good idea! I think. At least as a comparison.
I held them up to my ears, but the dog was snoring too loud to hear anything else.
Do the polyester ones sound like disco?
Seriously, when you're buying them you deserve to know the truth and get what you pay for -- even if you're deaf. Also, a listening test implies building two versions of a project, or swapping parts to compare. That's a lot of additional time & effort. I'd rather just use the ones with better specs, especially when temperature stability is one of those specs. The price difference isn't that much and I'm not manufacturing, so it's easy for me to justify. Your mileage may vary.
..Todd
Conrad Hoffman said:I'm probably a bit daft in the head, because as a child I inhaled the sweet smell of burning selenium rectifiers. Nothing quite like 'em. We won't even talk about the mercury experiments.
![cannotbe :cannotbe: :cannotbe:](https://files.diyaudio.com/forums/images/smilies/cannotbe.gif)
![bigeyes :bigeyes: :bigeyes:](https://files.diyaudio.com/forums/images/smilies/bigeyes.gif)
QSerraTico_Tico said:Heat them up with a hair-dryer while measuring capacitance...
analog_sa said:
If you can't tell by listening, do you really need to know?
![clown :clown: :clown:](https://files.diyaudio.com/forums/images/smilies/clown.gif)
..Todd
Re: Re: Re: MKP caps: are these for real?
Temperature stability? So, it's a non-audio project? In that case my suggestion is irrelevant.
If it is audio and quality is of any consideration i can simply find no justification for Chinese caps. PP or not.
..Todd
http://www.janson-soft.de/lcmeter/lcmeter.htm
Use google to translate the german, if needed.
This meter is very accurate and can also measure inductances.
I plan to provide a small kit on a my version of this circuit shortly.
Still fighting the battle of trying to use TI's microprosesors... These would make the battery last very long.
It is more accurate on small values than most bridges....
Burn a polyseter shirt to find out what it smells like......
Nordic said:This meter is very accurate and can also measure inductances. [/B][/QUOTE] It measures DA?
Re: Re: Re: Re: MKP caps: are these for real?
Thanks. I appreciate your input.
..Todd
..Todd
Where is Elso Kwak if you need him?
http://www.diyaudio.com/forums/showthread.php?postid=153877#post153877
Yeah, I'd be suspicious of claims for unknown brands of any capacitor; best to test.
A quick and dirty method I use to check dielectrics is to charge up the capacitor to a reasonable voltage and let it sit a while, then short the leads (not recommended with large capacitors and very high voltages!) and let the capacitor sit a minute or three (with the leads unshorted!).
Measure the residual voltage. Polypropylene, polystyrene and teflon types will generally measure around a tenth of a volt. Most others will measure at least a few tenths to a volt or more.
Measuring the ESR of film/foil versus metallized film requires more test equipment.
Re: Where is Elso Kwak if you need him?
Wow, thanks for this. Just tried it, works like a dream.
- Design & Build
- Parts
- MKP caps: are these for real?
