Mixed feedback
Yes, and the winding resistance of the primaire is the least of your worries when designing an ESL-transformer
What makes a good esl transformer so difficult to design is the combination of required output voltage (together with the v/turn ratio determining # of sec turns) and the large frequency range: the low frequency limit requires a large # of prim turns but the high limit requires low internal capacitances and low leak, what in turn requires as little turns as possible. In other words, the problems are at the secundairy side.
I am currently trying to design an amplifier/transformer combination that includes the transformer in the feedback loop. But it proves very difficult to obtain enough bandwidth
jcx said:
the question is could you usefully rely on this to extend esl transformer usable bandwidth lower limit
Interesting paper, thanks for the link!
I believe this method could to some extend be useful to lower low frequency distortion by the transfo, if it could be made to work properly in capacitive loads. But than again, I don't believe low frequency distortion is something to worry about. Transformer distortion will be overshadowed by other esl-related problems anyway (resonance, non-uniform membrame motion etc) in the low freq range.
But to answer your question, it will not extend the low frequency limit. The lower bandwidth limit of a practical ESL transformer is not set by distortion problems but by core saturation limits that impose a hard limit on the voltage the transfo can handle at a certain frequency, derating linear with frequency. In addition primairy inductance sets another limit (Zprim must not drop below what the amp can drive @ 20 hz). Whatever comes first sets the limit.
Well, the primary inductance is only a small signal aproximation. At large signals, close to core saturation, the value decreases.
And, yes, it works. I used it with line level transformers. It extends the usfull, as in some set distorsion value , low frequncy limit.
With transformers you could do as in quad 63s, use 2 for each esl. Then you can have half the voltage ratio.
That's a good way of doing things but the price you pay is lower primaire inductance as both primaire coils are in parallel and they don't share the same magnetic circuit.
Even better solution is therefore to place the two coil-former from those two tranformers on one core, which can be done by using two coil-formers on a double C-core. To my knowledge this is the best way to make an ESL-transformer.
At least I hope so, I am trying it right now 🙂
