Mission Model "750 LE" (Limited Edition - 750LE) vs. "750" - which Differences on Drivers and Crossover Network ?
As I know, the main difference consist on the enclosure resp. cabinet version. But maybe there are additional differences on the electrical parts.
Because on the web I have found only information concerning the "LE" version I also think it is possible that this model "750" was only manufactured and thus only available as an "LE" version.
Thank you for clarify.
P.S.: A friend of me want to replace the drivers for bass-Midrange and dome tweeter because the voice coils don't longer work in the right manner.
Which currently available drivers are close to those from genuine used ?
Thank you for an advice.
Here a review from the "LE" version
https://www.tnt-audio.com/casse/miss750e.html
One of this two versions was reviewed in German's audio magazine "STEREOPLAY", issue April 1998 and July 1999 (1000,-- DM/pair at those days).
Whether it is the normal version or the “LE” or “limited edition” version - that is the question (because "LE" isn't mentioned on cover and TOC - go to the attached images of this magazines).
Maybe someone has these editions from which this can be seen (maybe from an image of the terminal panel in one of these reviews).
Thank you very much.
While checking the web archive i note, that this model of the 75 series was generally not mentioned on the old archived Mission websites from 1997, 1998 and 1999 - go to
https://web.archive.org/web/19980122073609/http://www.mission.co.uk/75f_ser.htm
https://web.archive.org/web/19980122073739/http://www.mission.co.uk/751f.htm
When I change this archived URL from Mission 751 Freedom - go to
with "750le.htm" instead of "751f.htm" at the end, I get this page from 1999: https://web.archive.org/web/19990222010221/http://www.mission.co.uk/750le.htm
but with "750.htm" or "750f.htm" there is no archived web page goes open.
This can be seen as evidence that the 750le only existed in this version.
The assumption that there could also have been a normal version probably arose from the fact that in the tests of the good known hi-fi magazines there was always mentioned "750" ("750LE" was never mentioned at that time) and the designation "limited edition" in the style of a handwriting was only to find on the rear panel sticker.
Who can upload the pdf of the 750 limited edition in the same kind than those from 751 Freedom Compact Monitor
https://web.archive.org/web/19981203080710/http://www.mission.co.uk/ftp/751f.pdf
Some test reviews:
https://web.archive.org/web/2018071...aelectronics.xyz/audio_1998_Aug--Mission.html
  • Mission 750LE passive xover.pdf
