SOLD
Miro PCM1704 DAC board for sale. This board allows JLSounds i2soverUSB or York with reclocking to be stacked for a nice, direct interfacing.
There is no IV stage on this board. You will need to improvise your own IV stage.
Two pieces of PCM1704 J graded chips on the board.
*Important Note : These are recycled chips, which were removed carefully with proper heat control. They work perfectly. I do not source the chips from random Ali or Ebay. They are from a reputable source.
What you need to provide :
1. You will need to give it PSU with rails +/-5V (Analog) and +/-5V (Digital).
Optional - one +5V for the 'dirty side' of the USB interface if you do not want to have the USB part powered from the USB bus of your PC source.
2. i2s source - JLSounds i2soverUSB or York + Reclock is needed to feed it in order to play music. Both JLSounds or York have the mounting footprint to be able stack nicely on the DAC board
http://jlsounds.com/i2soverusbFIO.html
3. IV stage of your own - tubes, discrete SS stages, transformers .....
4. Chassis, wires, connectors etc
Board fully populated with good quality components.
DAC board + shipping registered & tracking = USD 165
Payment by PAYPAL FF please.
I have sent 50+ packages to US, EU and a couple to Asia. All receive the packages in good condition.
Hello DiyAudio community,
TL;DR: This is a USB transport for audio output (up to 8ch) and input (2ch for now) and user device control (e.g., DSP management) from PC (MacOS/Linux/Windows) thru I2C/GPIO. Including bootloader for remote firmware update, flexible device configuration, HID interface, multiple audio output options, integration with SigmaStudio (simultanious audio playback and ADAU DSP configuration). Compact module available in USB-C and USB-B versions, isolated or non-isolated.
Latest docs, config tool, link to buy:
http://york.eclipsevl.org/...
- eclipsevl
- Forum: Vendor's Bazaar
If you wish to be supplied with JLSounds or York USB interface to complete the kit, please DM to discuss.
