Exchange the 6.8uF of the tweeter network for 4.7uF. This should introduce quite an SPL reduction in the high pass zone.
Did you make any progress on your M-3si crossovers?
Did you remove the crossover and attempt any upgrades?
I starting to do mine and find there really isn't a lot of room to do much. If you got the cross over out, were you able to get the wires to the midranges out?
Did you work through the opening for the woofer, or did you try to take apart the cabinet (if it is even possible or advisable)?
Would be great to know a little more about what you did and how you were able to do it.
Thanks!
Thanks!
Hello. No, I have not done anything with the crossovers. I used the equalizer until I changed my speaker cables to Van Den Hul CS122. Then I could bypass the eq, believe it or not 😃 So for now I leave them alone cause I guess it's not easy to get the filters with wires out.
