Minnesota/Wisconsin/Iowa/North Dakota Cabinet Builders
Any competent cabinet maker should be able to do that if you supply the plans. Perhaps Google 'millwork' as an alternative to 'cabinet maker' which should give you a number of choices. Some may have a specialty, for example stairs, but should be able to direct you to someone else who could do the work
You might also consider Winnipeg which isn't that far from you and fortunately, for you, your dollar will go about 30% further in Canada.
Hey Adam,
I'm a furniture maker here in Minneapolis. I've done some speaker cabs and could potentially be interested. Contact me jholtzy at Gmail.
