Minisharc I2S out
I don't think so.
That connector pinout is standardized across the different miniDSP platforms.....not just the miniSHARC. The numbering scheme on the ID connectors has confused some folks. Are you sure you were probing the correct pins?
Dave.
Minisharc out
Hi Davey: Yes I am sure the counting is correct.
I've forgotten much of my advanced math but I'm still good up to 20😛
I didn't notice until I connected my DAC. Had to swap the leads.
I suspect something when wrong with the firmware update that ran
on first startup. I guess I should track down a way to re-run that.
Circuit boards and parts pins don't change on their own.
Firmware updates won't change the pcboard artwork. I believe some of the I/O's are reconfigurable, but I don't believe it's possible to confuse ADSP-21369 data with clock via a software update.
I suggest to probe the J2 pins with your oscilloscope and verify the waveforms.
Post your query on the miniDSP forum and they can tell you for sure. They no longer check this forum.
Dave.
