Minimun Components to TDA2030 and TDA1514
Re: tda 2030 and 1514
abidr said:
minimum components needed are mentioned in the data shhets of the chips try searching for data sheets an google, however on a personal note I'd suggests consider using something better like LM3886, as these chips wont blow up frequently as TDA 1514 or 2030.
In Brazil is so hard to find LM3886.
Because this, i'm using TDA1514.
The Datasheet use many components ?
I want to use the minimun to make the TDA1514 to amplify.
