One of my speakers is cutting out when i start to turn it up a bit.Seems fine at lower levels. Ive narrowed it down to my dsp board. Does anyone have any thought as to why this would happen or is it likely a bad board?
This seems unusual, so first be certain that it is the dsp and not elsewhere in your system or cables. Try to get the problem to change channels.
i tried that. No matter what i do its still the same channel that cuts out.
Appreciate the suggestion.
I also notice that the channel that cuts out seems to play slightly louder than the other channel. Very bazzar.
