My fault. Forgot what forum I was on! Could we see pix of your latest Pluto w/ dims please? No reducer? And of course...how does it sound ? Thanks, Dan
Could someone please explain the Fo of 70.6 and Qo of .55? My calculator says with a Vas = 19 L and Qts=.46 for the Seas you'd need a Vb of 1.56 cu. ft for a Qo of .55 ? Thanks.
You're using the wrong numbers for the wrong driver. Fo-70.6 and Qo-0.55 were measured on the original Pluto configuration using the Peerless driver.
Dave.
Dave.
Ha - sorry. I guess there are no numbers using the Seas? Here's a thought from an engineeringly challenged person ... is it correct that any Qtc can be obtained through ASP or DSP means? ...fire when ready. - Dan
Sure there are numbers for the Seas configuration.
Pluto-2 omni-directional loudspeaker
There is much information on the Linkwitz site regarding the various iterations of the Pluto system. Check it out.
Also the Thor pages are a comprehensive description of a closed-box woofer system design and execution.
THOR - subwoofer
There are numerous texts and online articles regarding electronic equalization and its ability to modify woofer system parameters such as Qtc. The answer to your question is "yes"....within reason. There are real-world physical characteristics that ultimately limit all systems.
Dave.
I'm now using my Orion's with the MiniDSP for some time now. Its working fine and the only thing I'm working on still is adjsting the volume.
Although I've bought the FP-VOL, using it is not that user friendly. I'm therefor designing an 8 channel Up controlled analog volume control with a 0.02dB deviation.
I would be interested to know more about this volume control you're designing.
What do you mean by "up" controlled?
Will it be 8 channels of balanced volume or single ended?
Ideally I would like to use a PIC to control the volume. It can be either single ended or ballanced. The number og channels can be extended.
Who would want to work with me to program the PIC?
The Idea is to use 16 datalines for Volume contol, 4 datalinen for input selection, 1 dataline for remote input, 2 datalines for volume digital pot, 2 datalines for input selection pot and setup.
When someone is really in the mood I would like a WEB interface as well to control input and volume.
Anyone who can/will help me with this?
Personally i think volume control is a key issue with the miniDSP kit. I have spent too much time thinking about it! There are more options now with digital in/out boards (nanoDIGI / miniSHARC).
I'm not a great fan of their volume implementation (VOL-FP), it could be better if they updated the software i think. At the moment the manual rotary requires too many turns and isn't practical. There is always the concern that there is a malfunction or, more likely, power outage (or accidental switch off) which can generate a loud pop in an active speaker scenario. I'm always a bit nervous about having the vol control there.
Excellent and value for money as the miniDSP is, the analogue stages aren't low on noise (not bad, but not great, depends on a number of factors....in my experience). Makes sense therefore to max the SNR from the miniDSP and feed that into high quality volume control.
That's why personally i would be interested to see a high quality implementation of an 8-channel balanced (remote) volume control situated after the miniDSP, with protection muting. I think it could sell well.
The VOL-FP is not really the volume control, per se. That's just the external adjustment access. The actual volume control is performed in the DSP with no bit loss at anything other than very large attenuations.
The turning of the rotary control (and 0.5db steps) can easily be changed with a software update. Why not request this from the miniDSP guys? I'm sure they'd be open to the idea.
The popping on turn on/off has been remedied in the 2x8 board nearly two years ago and if you have an older one it can be retrofitted with a component change to fix.
Dave.
Dave.
Good to know, i will contact miniDSP see if my 8x8 can be retrofitted and how.
Think the volume adjustment has already been brought to their attention.
Yes volume all done in DSP, not concerned about loss of quality with this method, it works well if the noise floor is low enough.
OK, here it is!
http://www.diyaudio.com/forums/multi-way/259189-new-linkwitz-lxmini-speakers.html#post3991885
Davey;3991064 It's probably worth starting another thread.
Dave.
Does anyone have a fr graph to use to equalize an aurasound whisper. I don't think the factory graph is that accurate. I read that there is a peak around 4300 hz?
Yes indeed.....although your query is more related to the Pluto speaker.
Check out the Pluto pages for a look at the measured response and equalization applied.
Pluto electronics
Dave.
Pluto electronics
Dave.
Thanks, it looks like the baffle step around 2000 is included in his measurement, so its not the same as my application. Still I put about a 2db dip around 3500-5000 and it helps a lot. Equalizer APO makes it easy.
Aurasounds are world class mid tweets, wouldn't want to use them in a passive speaker though.
The application doesn't matter. That driver has an inherent peak in the frequency response in that range.
Dave.
