mini speaker with D-class ampli
Hello Everyone, I have just joined this wonderful forum, I'm Following some time, because I find it very interesting and complete.
I'm venturing into the construction of a small portable powered speaker with 4 full band 1.8 "of the k-tone for the upper middle section, and a driver TB Speakers, for the low.
I would like to ask if any of you have already experienced some solution of this type.
I'm trying to identify the amplifiers to be used (1 stereo for mid high + 1 for the mid low).
I would use the amplifiers d-class because they are compact and do not use heat sinks, dispose of lithium battery pack from about 12V and 4.5A which reaches a minimum voltage of 8.5V before intervening guards, and that I would have at least 4-5 hours of music, which amplifier modules would you use?
I tried to watch Pam8610, but have a minimum voltage of 9V .... what do you think of the TPA3110 ?? also they work to 8V and for me would be fine, but just do not know them .... help !!! ;-))
Thank you
Enrico
