Mini-Me MM phono PCB´s
Hi Boydk,
Thanks for the follow up and don't worry for the post closed, we aren't in hurry 🙂
By the way, I have a simple question : I have seen that the PCB use 8-pin socket for the tube, can you confirm that pin 1 of the tube is pin 1 of the socket or if not can you give the pin-out of the socket ?
Thanks & regards,
Marc
Hi Marc....
Haven´t really gotten that much into it yet, but what I can see from the layout, pins 4 & 8 are the heaters. It should be pretty straight forward from there 🙂
Koifarm suggested, that he will be supporting builders in the original thread:
Mini-Me phono preamp
He can probably (or flancfuster) give you the final answers on this 🙂
EDIT: but yeah.... looking at the tube datasheet pins 4 & 8 on tube are also the heaters, so my guess is, that the socket connections follow the tube pins number wise.
Shipped today.
So all these are dlivered, stamped and ready to go from the post office 🙂.
I did a shake test on the bubble envelopes, and didn´t feel too secure, so they were all packed in an additional hard paper envelope. Just tell you, that I´m not totally stupid, when you unpack them and find name and addresses again on the inside😀😀 Hope these all reach you safe and sound.
Still 2 set´s of PCB´s to go. There´ll be an increase in shipping since (I just found out at the post office 😕) the postage is 9.5Euros and not 6 :cheerful: so for the 2 set´s left it is 12Euro pr. set and 9.5Euro´s shipping = 21.5Euros 🙂
For some strange reason, the stupid post office has started opening up again on saturdays, so RE 604.......... Your PCB´s have shipped today 🙂
So this was "the end". No more PCB´s. Thank you all for your interrest. Hope you all receive your PCB´s soon 🙂
