Everybody,
I wonder if anybody knows what softdome midrange is used in Quested Monitoring( www.quested.com ) speakers. I see 2 kinds of 3" soft dome midrange, and sure that one is from Vifa. But not sure about the other used in more expensive systems. It looks like ATC SM75-150, but the texture of the dome looks a little bit different, and the waveguide looks straight, different from the curved waveguide in current ATC SM75-150. It was interesting that they were using Volt drivers very thoroughly, but no idea about big yellow dome... Can anybody share info. if any?
Hmm, pretty sure that the one in the active systems looks like an ATC 3", possibly the SM 75-150s version (450W amp power into this baby?). You are right, the mid in the Passives looks like a VIFA. Hmm, $550 difference just in the midrange. I guess it is justified considering the price. But, I could be wrong.
Konnichiwa,
The way i was told this Quested originally used ATC but got chessed off about a few things so they had an improved copy made (probably made in the far east, but maybe Vifia - who knows), so this unit is strictly OEM.
Sayonara
jheoaustin said:But not sure about the other used in more expensive systems. It looks like ATC SM75-150, but the texture of the dome looks a little bit different, and the waveguide looks straight, different from the curved waveguide in current ATC SM75-150.
Sayonara
Thank you for your informative reply about something difficult to find. I appreciate it.
Just one thing to note, I am not a Japanese. 🙂
And all the answers are wrong.
Quested uses the Volt VM752. They did use the ATC but when they started selling greater numbers ATC stopped supplying Quested so they approached Volt to make a replacement.
Same thing happened to PMC who now make their own 3" dome.
- Midrange used in Quested Monitoring?
