Midbass horn round 2
Ok so based on hornresp alone. S1 in this cabs case is 200. Reducing this impacted the output badly.
If I was to integrate a phase plug wouldn't I do it as an insert into a larger S1 to maintain the throat surface area?
I'm trying my absolute best to replicate the sim because this cab is very sensitive to changes.
hi klampykixx - if you draw up a plan - I'd like to see it. It would be nice if weight can be kept down yet keep it rigid. What does that little 12cm "flat" section do?
