mid/tweet power division ?
Hi All,
I've been looking up on the division of power between mids and tweets for a bi-amped system..
I'm designing my speakers to go to 105Db peaks, with an average of 85Db. (Mid - Tweeter x/o @ 3000Hz)
The only info I've found is on Rod Elliots site which states that at 3000Hz the power is split 85% - 15%
Therefore, if the mids are peaking at 105Db, can I assume my tweeters will peak at 105/85 * 15 = 18.5Db ?
If so, as they're 92Db sensitivity I can happily use a 2.5 watt amp to drive them..
Hopefully somebody can confirm for me,
Cheers
Rob
Actually, your calculations are a little strange, but you somehow arrived close to the right answer!
Here's how it should be calculated (I'm sure somebody here can double-check for me). You need to do the antilog before multiplying with the percentage ratio:
You want 105dB SPL @1m and speaker efficiency is 92dB/1W/1m. So you need a total amplifier power of 10^((105-92)/10) = 20W
Tweeter needs only 20 * 0.15 = 3W
Mid needs 17W, more if it has less than 92dB sensitivity.
But remember that Elliott states on his page that the 85/15 ratio is on average! Which means that with certain music the tweeters may need much more than 3W.
