mid speaker watts?
Disabled Account
Joined 2006
For tweeter PA-D44 Paudio spec sheet say 30W@ 1 khz, 50W@ 2 khz.
Can this be applied to midrange speakers?
The speaker Fs is 55hz and manufacturer claim that it is rated for 300 Watts.
If i use it in sealed box & Fs (with hp filter) as 150 hz, will the power handling change?
1) Post the midrange specs and model, otherwise it's a guessing game.
2) how will you drive it? (Active/passive).
Ans :
Specifications :
Nominal Diameter : 12” (320 mm)
Impedance : 8 Ohm
Voice Coil Size : 75mm(3")
Frame : Aluminium
Magnet Size : 190 mm
Power Capacity : 300 W RMS
Voice Coil Former : Kapton
Voice Coil Material : Copper
Fs : 55.2197 Hz
RE : 5.6 ohm
QES : 0.3809
QTS : 0.3606
SPL : 98.54
MMS : 49.399 g
VAS : 76.977
B/L : 16.573
2) Driving the driver with passive network
