Mid range to Full Range Conversion.
I simply want to extend the cutoff range down so that the satellites become full range speakers.
The woofer is 8ohm and tweeter is 4 ohm.
i attach the crossover diagram bellow
Hi, you obviously failed in designing the crossover circuit-
It happens to me either !
The 200 uF cap could be seen as an high pass component, but it could work together with the woofer's load -is it a closed box ?
Edit: uuhh, sorry: you crossed the outputs so I was watching at another thing!
So the circuit is right...mmmh, maybe the 16 uF cap is after wooofer's inductor ? The white thingy is a resistor
Still missing the Bennic MPK cap that is obviously in serries with the tweeter....check that out !
this is a satellite speaker that comes with GIGAWORKS S750. crossover network is built in for mid and tweeter.
I want to make this satellite mid-range speakers to a full range speaker with some DIY!!
i dint make any modifier yet! i just open the box and got scared!
