Some friends and I were auditioning an expensive (but nameless ) pre-amp for the last three weeks and something happened that I am at a loss to explain. When first played as it arrived, with the stock tubes, it was horribly microphonic. One could literally stand next to it, talk in a normal voice, and hear what you were saying from the speakers. Tapping lightly on the chassis produced a loud ringing sound. Later that week the tubes were replaced with tubes that were selected for low microphonics (12AX7A, 5965, and 6080WB). This helped a little, but not much. Last night, the microphonic behavior was almost completely absent. The only difference in the listening sessions was that the pre-amp had been warming for about twenty hours rather than the usual seven or eight hours. What gives?
John
John
Yes that's right....
And some other thing is that "new" (NOS/NIB or not) tubes needs a few hours to burn in. For example, the mica parts that maintain in place the anode, cathode and so one have to move a little bit when turning hot / cold / hot /
Another way to explore is to have a look to the schematic.
If a SRPP or like, the filament power supply must be referenced to HT/4 minimum or tube might "ring" and be microphonics.
the other method is to use different half tube for each part of the SRPP.
