Hello,
I am user of cd plyaer micromega stage 1 serial number 1160. I am looking for memory dump (image) of eprom 27c256 because the eprom of my stage 1 is damaged.
The file disappeared from the eprom memory. Maybe someone has the eprom memory image from micromega stage 1,2 or 3 ???
Best regards.
Tomasz
Best regards.
Tomasz
If you are in Europe, you may want to try to contact them.
They service old Micromega players, and speak fluent English without saying.
HiFi.nl - winkel 172 De Hifiwinkel
Patrick
Patrick
Hi toom,
I own a Stage2 (S/N 21) with v1.3 firmware. I have the image of the PROM in hex format. As far as I know, the firmware was the same for micromega stage 1, 2 and 3, may be mine could work. You will have to get all the necessary to get your PROM written, I cannot do it for you. Of course, you'd better buy a new EPROM. The model I have on my stage 2 is an NM27C256 from National Semiconductor.
Besides this, I don't know if the solution I suggest is allowed by Micromega...
May be you can also have a look on my pages : Ptit Four There is not much about my Stage 2, I still have to write about it. I slightly modified the DAC, but I am also thinking about designing my own DAC.
Laurent
Laurent
