MicroCap 12: Problem simulating imported PSpice model (LM3886)
Hello,
I'm new to uCap12 (and simulation in general) and I'm trying to import and simulate a PSpice (.lib) model file which I downloaded directly from TI.
I have copied to .lib file to the main LIBRARY folder and then used "Add Part Wizard" tool to import the model, I selected the 6 pin op-amp model and renamed the pins as they appear in the model file (.SUBCKT lm3886 Vip Vin VDD VSS Vout MUTE)
I constructed a simple circuit and wanted to run the simulation but when I do that uCap shows me the lm3886.lib file and highlights a diode model:
".SUBCKT IDEAL_DIODE_0 A C
+PARAMS: EMCO = 0.01 BRKV = 60 IBRKV = 1M)"
I assume the lm3886 model is relying on another uCap native diode model to work, and that is missing?
Any ideas of how to get it to work would be much appreciated.
Thanks!
