mh Warehouse light f/s
I aquired this from a warehouse that was being torn down.
The bulb is a 400w mh. The reflector is all glass:nod:. I am selling it due to the fact that it is to big for my set up(I thought it would work I was wrong) I will let it go for $70us plus s/h. I paid a little over 200 for it. Comes with everything(i.e. reflector, bulb, ballast, and everything in the picture)
Or I can part it out. also there is no warranty on it as I have not tested it, but the warehouse it came out of was operational up to the day they tore it down.
Shoot me a line to check price on indiviual pieces or to check on shipping 🙂
Ok here are the dim. finially
reflector: 16" wide and 11" high
bulb: Sylvania 400w mercury h33 h33gl400dx
11" long and 5" wide
ballast: due to the fact that I can not get the screws out I have no true idea how small the ballast is(or th case is the the complete ballast so here is what it said on the side:
903 277 v.q q3913277vq
use 400 watt h33-l lamp
pri volts: 277 pri amp: 1.7
power factor: high 60 hertz
suitable for amb up 55c use 90c supply connections
lb1405-d
