I want to know if Metronome module can convert 16 bits MSB first right justified (EIAJ) to I2S?
If yes how can proceed, changing SW2 switches to accept 16 bits Right Justified:
IFMT2 1
IFMT1 0
IFMT0 0
IFMT2 1
IFMT1 0
IFMT0 0
Merlin,
The SRC4192 does not say that EIAJ is supported - I am not really familiar with that format.
If the inteface timing is as the datasheet dictates it should work.
If you have tried it and it does not work then either the format is not supported or there is another seperate issue - maybe wiring the wrong signal etc - it's impossible for me to say.
