Sorry about the lack of detail!
The main object to support is a 25 pound toroid transformer. The toroid transformer is about 12" in diameter. I am looking for a solid base to set it on. The plate would have four rubber feat beneath it.
--> I used to use a sheet of aluminum to support a similar sized toroid for a different project. After I disassembled the project, I realized that the aluminum sheet I used wasn't strong enough because there was a large indent in the metal where the toroid had been mounted.
