Hello,
in former tube amp projects I used the 1W Beyschlag resistors.
After the last order they came up with a slight different color and dimension. The new production seems to be much more magnetic than the old.
So I´m looking for good alternatives.
I thought of using Vishay CMF70 but unfortunately I couldn´t find a supplier with a bigger range of values.
Which 1W metal film resistors would you recommend? They should have a precision of 1% or better.
Best,
Rents
Best,
Rents
When asking for help it helps to have your location, including at least continent, on your personal details. My supplier, Newark.com, has a lot of Vishay metal film resistors. I buy the 5% tolerance, but the dozen come in all the exact same value mostly, so the precision is there, if not the accuracy. I find 1 w resistors too low in voltage rating to do the plate resistor or other high voltage applications, so I buy the two or three watt packages for tube circuits. Newark's multicomp generic brand seems to be exactly similar and has the same countries of origin. (In or Th) The two plants have somewhat different paint characteristics. I haven't compared the sources against each other, but both sources are way better in noise than the carbon comp resistors I have been replacing.
