Hmmmmmmm the minimum is set to 1 character here so I dunno how you could be getting a TOO SHORT error unless you tried to send it WITH NO TEXT.. (Which obviously ya didnt)
Now I managed to do "Quick reply" on the thread. But I got the same message both at home and at work, and the text was certainly more then 1 character. I used different browsers too. I could not attach images either.
Hmmm Now there is a 2nd user reporting this using IE8 but seeing you tried different browsers with the same result,its confusing!!
Does this happen ONLY WHEN YOU USE QUICK REPLY and not the FULL EDITOR??
I have observed the same issue tonight with several of my posts.. I've also had some where I quoted someone else and the quote showed but my text disappeared into oblivion when I posted. 😱 😀
I never use quick reply...
What browser and OS are you using? I'm using FF 25.0 on Win 7.
Will let the right people know..
I've had two posts where I used quote, where the quote appears but none of the text I entered. FF 25.0 on WinXP.
Tony.
Tony.
There was a problem with log files that was causing issues with image upload, hopefully it was also the cause of tthis problem (as it has been fixed). If you are still having the issue please post again here.
Tony.
Tony.
- Site
- Forum Problems & Feedback
- Message too short
