Mercury magnetics FBfd-om in matchless spitfire
Pin 9 is the screen voltage. If your plate volts are stable but your screen volts dropping, you need to check that 100 ohm resistor. They can get fried if not high enough wattage rating, and may have been damaged if a bad tube or previous wiring problem. Screen voltage variance like that would explain your volume dropping out momentarily. What is the present resistor rating?
Worth a try, and if you have access to another power tube as well may be worth trying too. I am still trying to figure out the variance in glowing on the tube. Double check your bias and maybe decrease it a bit? just suggesting.
I´ve tried 2 different sets of el84s and a couple of russian 6p14p-ev.... they are rugged tubes that ought to take the abuse 🙂
re-checked my wiring, and every single component value tonight...
This one is gonna be hard to solve, I think
