Meng 6PI Biasing Question
Often the Meng 6P1 has 4 trimpots, 2 for hum balance and 2 for phase splitter balance. The output valves are 6P1 (9 pin) and not 6AQ5 (7 pin) but they are generally considered equivalents. The output valves are self-biased so just fit the new ones, no adjustments should be needed. The Mengs I have seen have the 4 trimpots near the front two input stage valves, not the output valves, so if you have trimpots under the bases of the output valves then disregard this info.
