Could someone please tell me the transistor that a located at the following location on a Memphis pr1.1000 circuit board:
ic11a
ic10a
q10a
q10a1
q10a2
q10a3
q11a
q11a1
q11a2
q11a3
q11a4
ic11a
ic10a
q10a
q10a1
q10a2
q10a3
q11a
q11a1
q11a2
q11a3
q11a4
Which two legs of IC10 and 11 are connected together?
From what I can tell from the photos I have...
Q10... are all FQP19N20s
Q11... are all IRF9640s
There are not connected ,ic10a and ic11a are the two transistors to the far right of the circuit. I was just wondering if i could assume that ic11a would be the negative and ic10a would be the positive giving that a10s are n-channel and a11s are p-channel
You shouldn't assume anything.
Did you use a multimeter to confirm that there are no two pins from those ICs that are directly connected?
