megaphone horn speakers for guitar
I'm building a guitar amp and i'm not looking for bass, only loudness (i like the mid/hi tone better). Would midrange horn speakers (like the ones on megaphones) sound okay for this or would they be to echoing, resonant, etc. Also dispersion ... do they only have a high on-axis SPL or would they beat non-horns on the off-axis too? Anything else i should consider?
Nobody uses horns for electric guitar because they are too efficient and therefore too clean. Electric guitar is the one application where speaker coloration is actually a desired trait and distortion is a good thing. If you prefer a strong bottom use a sealed or vented box; for a stronger midrange go with an open back. Leo Fender and Jim Marshall got it allmost right in the 1960's. Do what they did and stick big speakers in a small box, but if you use more than one have them vertically aligned, never side by side. That's the one thing that Fender and Marshall did wrong.
www.billfitzmaurice.com
This depends on personal taste of course, but most lead players prefer a combination of amp sourced and speaker sourced distortion. There are those who prefer to have all their distortion effect sourced, and have the amp/speaker totally clean. It all has to do with what kind of tone you're looking for, and that only comes from experience.
But as for horns they simply aren't used, partly because they also extend higher in response than cone speakers, and the kind of distortion that sounds totally sweet at up to 5kHz or so sounds like nails on a blackboard at 10kHz.
Horns are used in amps for acoustic or quasi-acoustic guitar, to add the high harmonics that differentiate the traditional sound of an electric from an acoustic.
