Medium Power SET, EL156 based
I'm not sure you will - the max anode voltage is too low!
You need an ECC82 or a 6SN7 I think...
Save the ECC88s for a phono stage 🙂
Hi !
I will use ECC88 for that purpose,because the EL156 only needs less than 10Vpp in grid for full power,it is a very special valve,i think!And i like very much the sound of ECC88! I have to check the price for sowter transfos for this,i heard they have very good quality,but i am not a rich guy ,so if not sowter,maybe Hammond!
Silvino
Hi !
How about EL156 SE Ultralinear? You will have more power,with good performance! I want to make a similar amp,but not decided yet the configuration to apply! But i will use a ECC88 to drive the EL156.
When you finish the amp,let us know about the sound with the Sowter transfos!
I wonder if Ultra-Linear will have the same magic sound quality as triode. As I wrote, I'm not into a race after max power.
Once the amp will be running, I'll report the good, the bad and the ugly about it.
Hi !
Silvino
Yes, it's the perpetual debate between sound quality and cost. Since this one will probably be my last amp, if it will sound good, I intend to go for the best I can afford.
Hi !
Silvino
10Vpp is very impressive! Be interested to see your design, I have loads of ECC88s here 😉
Hi Joshua,
I just bought a special publication from Elektor "Röhren 6"
which happens to contain an article about a single ended
EL156 power amp. Triode and pentode mode is switchable, the
(measured) power at 5% THD is 12.5 W in triode and 20W in pentode
mode. They use one ECC99 (dual triode) per channel to drive the EL156.
I can only guess roughly from the triode strapped anode curves.
Anyhow, for the time being I dropped this project in favor of another one.
Hi Joshua,
if you are still interested, I was able to drop down the distortion and make mine sing and punch. Pretty cheap mods also. However, no good results with the EL156, I am using 6550's. I am designing another SET amp around the EL156 in a 2 stage. I will build it later as I am having lots of fun with the present one.
I made a pair of (Shuguang) EL156 SEUL amplifiers driven by the EF86. Tube rectified, Hammond iron, Russian Teflon couplers, etc etc. Nothing special, but I still consider it my best DIY amplifier ever.
Having said that, they now runs real Tungsol 6550s and have found a place with a friend of mine. They sound even better with the vintage output tubes and GEC CV4085s for the input tube. A nice low powered amplifier which is perfect for his small room. I would have kept the amplifiers, but I went on to the power hungry planar speaker world.
Hi Joshua,
Are you have scheme of this amplifier? I have pair of ECC99 and I bidding original Telefunken El156 on eBay🙂
http://oldradio.qrz.ru/tubes/foreign/02/EL156.gif
Extrapolating from the above (in SE triode mode with an EL156) should yield 15W audio output:
Ua = 500V
Zout = 2.8Kohms
P(out) = 15W
Ia = ?
500V x .090A = 45W (Pd looks about right)
Find a good drivestage, and it should reach ~15W. 15W is sufficient to drive most speakers, and 15W are a lot of nice SE triode watts. (Average listening level is 10-12W.)
The PP triode config in the data sheet looks like best. 30W audio output - about 6 watts better than most KT88s in PP triode - unless the specs are way off.
